10 Pages «<23456>»
Tigerace`s 1/16 Trumpeter King Tiger Options
#61 Posted : 19 October 2021 11:57:09
Then started on the clean up and assembly of the wheels BigGrin
Kev the Modeller
#62 Posted : 19 October 2021 20:24:22
Yikes!! I looked in on your build Phil and thought I'd tuned into an episode of David Attenborough's 'Blue Planet'!! With all of those wheels laid out in rows like that it looks like the suckers on a giant octopus and he's wrapped his arms around your modelling bench! Laugh BigGrin
I don't envy you cleaning up and painting that lot, but making good progress with this already!! Blink Blink
Kev
Per Ardua Ad Astra
#63 Posted : 24 October 2021 10:52:46
Yes was quite time consuming KevBlink each wheel is in four parts Blink took quite a few sessions BigGrin but got there in the endCool
Regards PhilCool
#64 Posted : 24 October 2021 10:53:26
Next the torsion bars to clean up Blink
#65 Posted : 24 October 2021 10:54:22
All cleaned and then glued together BigGrin
#66 Posted : 24 October 2021 10:55:33
the rear fire wall has some moulded on detail to remove Blink
#67 Posted : 24 October 2021 10:56:48
The final drive housing`s glued and cleaned ready to goBigGrin
#68 Posted : 24 October 2021 10:58:22
Rear idlers put together BigGrin there are injector marks but only on the rear surfaces and can`t be seen BigGrin
#69 Posted : 24 October 2021 11:01:03
Then the Drive sprockets Blink these where cleaned and i will be adding some mr surfacer to show the rough casting on themBigGrin
#70 Posted : 24 October 2021 11:02:36
The scratch built junction electric box BigGrin added to the reworked kit transformer boxCool
#71 Posted : 24 October 2021 11:04:38
Next the shock absorbers added BigGrin along with more reworked parts at the drivers and radio operators station sponsons sidesCool missing parts and i moved certain parts as they where in the wrong placeCool
#72 Posted : 24 October 2021 11:08:21
Then the internal floor ribs added along with the heat extractor trunking for the gearbox Cool
Kev the Modeller
#73 Posted : 24 October 2021 12:32:45
Nice work on this Phil, really making some good progress with it and well done you for your perseverance with all of those suspension parts, wheels and sprockets! It can be boring doing repetitive assemblies like those but I find a constant flow of good coffee and some good music usually keeps me at it and then it's all done before you know it?!
Well done! Cool ThumpUp
Kev
Per Ardua Ad Astra
#74 Posted : 26 October 2021 11:57:21
Kev
Thanks KevBigGrin and yes mate did it in sessions so not to get frustrated as one can Laugh
Regards PhilCool
#75 Posted : 27 October 2021 08:44:36
Hi looking good phil lot of work ,but all adds to the detail look forward to more cheers mick.BigGrin
#76 Posted : 27 October 2021 10:52:28
Crikey!
All those wheels and sprockets would drive me nuts!
Amazing work there.Love
#77 Posted : 01 November 2021 11:49:52
Thanks for looking in Mick ,RoyBigGrin and your comments and your right Roy can be a little tedious at time`sBlink but i do them in sessions that way i don`t get stressedLOL LOL got the tracks to do yetBlink Blink Blink
Regards PhilCool
#78 Posted : 01 November 2021 11:51:26
SO i fitted the next update to the side sponson on the radio operators side which is the( missing from the kit) shock absorber cover BigGrin
#79 Posted : 01 November 2021 11:55:26
while waiting for some supplies to arrive pewter sheet and paintBlink i started on modifying the gear box and its cover here on the front part i rounded the edges as these parts, as they are cast on the real tankBigGrin so also will be adding rough texture and the casting number`sCool
#80 Posted : 01 November 2021 12:00:10
Then the cover which is wrong Confused missing detail and the appearance when finished will be seriously altered ,so all the detail was removed and filled and then set about correcting itCool pictures are before then after but still quite a lot to add before i move on from this partBigGrin
10 Pages «<23456>»
This page was generated in 0.432 seconds.
