24 Pages <1234>»
#21 Posted : 28 September 2011 21:56:56
had a slight problem with one of the tools in the kit provided with issue no 4 the circlip plyers,the lower prong [in the picture] is bent at the end[ about 6mm from the end] thus there not much use. but the akagi set seems fine
#22 Posted : 01 October 2011 17:45:44
BigGrin After some more fettlin heres the result on the baseLOL
#23 Posted : 20 October 2011 23:15:29
BigGrin A few more pics on my progress on pack 5 more pics to come
#24 Posted : 20 October 2011 23:25:04
Excellent work ARCool BigGrin
#25 Posted : 21 October 2011 20:52:15
BigGrin Thankyou MWG
#26 Posted : 22 October 2011 16:19:13
BigGrin Afew more pic,s
#27 Posted : 22 October 2011 16:22:35
Blink A load of fettlin and filler used here especialy where the parts 1/2 and 4 join together,maybe down to iffy castings but might even be me rofl, anyways on to the planking nextLOL
#28 Posted : 22 October 2011 20:08:05
I love your dedicated preperation to the metal piecesCool BigGrin
#29 Posted : 23 October 2011 02:03:58
BigGrin Thanks MWG but as my dad used to say preperation preperation [ he was a cabinet maker] saves you time in the long run, and i think im going to do the tower again as im not happy with it. but thanks for the kind coments and encouragment
#30 Posted : 23 October 2011 10:36:04
Its a must with all the metal bases, simply because there would be some very visible, wide and deep joint lines.
Good luck with the metal-working Cool
#31 Posted : 23 October 2011 19:47:43
Thanks Mr T
yes your right about the gaps in the base plates wide enough to park a bike in but with filler and filing a reasonable job can be achieved
AndyCool LOL
#32 Posted : 23 October 2011 20:20:15
what filler are you using Andt?
#33 Posted : 23 October 2011 20:36:24
BigGrin Hi MWG
For the smaller areas /joints i use MDD green putty and the larger areas im using P38 easy sand car filler [the pinkish looking one] as its more economical, hope this helps
#34 Posted : 23 October 2011 20:38:06
Spot on thanks AndyThumpUp
#35 Posted : 29 October 2011 13:39:59
BigGrin Ok heres the lower planking finished but not sanded as yet so its a warts and all diaryLOLand yes i made a few misstakes but not too bad as its over 10 years since i last planked a modelBlink , i used all my off cuts left from the previous planks that i added [and yes i know its says to save them in the build instructions].But i think il have more than enuf in the supplys to come to do all thats needed to finish the hullBlink,So its a good rough sanding thats next on the agenderLOL
#36 Posted : 29 October 2011 17:42:55
Andy your build is a credit to youBigGrin Cool
#37 Posted : 29 October 2011 18:14:07
Blushing Thankyou MWG
Wilfy the Sea Dog
#38 Posted : 30 October 2011 00:24:46
Hi Andy,
Build looking great, I've struggled a bit with filling some of the gaps in the metal components, maybe me being to scared to add so much filler!
I've tried to source the Squadron Green Putty & getting an average price of £5 per tube (delivered) does that sound about right? Seems a bit pricey.
Thanks
Wilfy
#39 Posted : 30 October 2011 02:06:41
BigGrin Hi Wilfy
thanks for the kind words,i paid £5.99 for my green putty and around the same for the p38 so at £5.00 its a bargain also the green is best used on small joints [ like gaps in the bridge structurs ect]the other thing is you only use half a pea size blob of green at a time as it goes along way in coverage . For larger areas i use P38 easy sand as its more economical cost wise, if u look at my metal parts above u can see where iv used the green and the p38 also dont be too fussy about using alot of filler as long as you spread it evenly and in several thin coats [ if needed] both are easy to sand down afterwards
#40 Posted : 30 October 2011 10:41:31
BigGrin Hi all
Just wondering if im the only builder of the Yamato as post on the other diarys have dried up Confused it would be nice to see other peoples progress aswell as my own and Mr T's official build but hey ho upwards and onwards.
A few more pics of the rough sanding finished,when i recieve the hull templates it will be shaped to the corect profile. Not a brilliant job but no gaps as such and no filler used as yetBlink [a few small spots might need some in the final profiling].My next instalment of the akagi is in the post so the next update will be in that diary
24 Pages <1234>»
This page was generated in 0.258 seconds.
