water line and copper tileing Options
nelson
#1 Posted : 29 September 2011 13:55:40
Hello everybody in the boat yard just a quick question when will we mark the water line and when is it best to start copper tiling the model please reply.............THANKS
john Ralph
#2 Posted : 29 September 2011 15:19:03
waterline marking in issue 66 according to Tomicks build
Deepseacodmaster
#3 Posted : 30 September 2011 10:03:03
Hi Nelson
I would recomend marking the waterline as per the instructions for copper ttiling at http://forum.model-space.co.uk/default.aspx?g=posts&t=2981 Markiing the waterline as per instructions in issue 66 would make the tiling of the wales very hard.
I had reached issue 40 before these instructions started. I have completed the tiling as far as the instructions go and am now continuing the build and have reached issue 50. I am waiting for the next instalment of tiling before continuing with it.
The only difference I have made from the instructions is that I have painted the hull with the copper paint so any small gaps I leave in the tiling do not show up.
Good luck with it all
BigGrin BigGrin
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
jeff averre
#4 Posted : 01 October 2011 00:49:08
Sorry to butt in on this topic as I'm not copper tiling, but have noticed one or two shipmates are painting then tile'ing! will this not mean that the glue will only be as strong as the paint?
I'd hate to see tiles dropping off at a later date!Confused
Jeff
#5 Posted : 01 October 2011 16:32:11
you raise a good point about using adhesive on paint. the short answer is yes, however if you do not undercoat first the paint will be absorbed by the wood still leaving a good rough surface for your chosen adhesive. there really is not a need to paint first as there should be no gaps big enough for the paint to be visible and the tile and the paint look very different.
This page was generated in 0.365 seconds.
