52 Pages «<4243444546>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#861 Posted : 11 November 2021 22:55:37
That concludes this update, more content to follow next week.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#862 Posted : 13 November 2021 17:56:15
Great work as always PhilBigGrin looking forward to seeing this room built upBigGrin
Regards PhilCool
Kev the Modeller
#863 Posted : 17 November 2021 22:06:38
Nice work as always Phil. It must be a pleasant and welcomed change for you to be able to do some larger pieces instead of all of that micro-surgery and miniature painting that you've been doing recently!
Keep going, looking really good! Cool ThumpUp
Kev
Per Ardua Ad Astra
Sticky Wickett
#864 Posted : 18 November 2021 21:29:35
Good evening from 'the Dockyard'.
So more progress on fitting out the Torpedo Compartment.
The attached photo shows the etched brass deck plate, painted, pin washed and fitted.
Sticky Wickett
#865 Posted : 18 November 2021 21:30:28
Looking from another angle.
Sticky Wickett
#866 Posted : 18 November 2021 21:36:13
I then turned my attention to the torpedo tubes. The basic resin castings i bought, along with 2 torpedoes, from a guy in Germany back in April 2015. I think i was one of his last customers, as not long after, he shut up shop. Glad i found him when i did, as it has saved me a lot of time.
My intention is to make one of the torpedo tube rear doors hinged and in the open position as i want to show a torpedo in the process of being loaded.
The attached photo shows the tubes being prepped and at this stage i decided to cut off the rear doors on all the tubes instead of just the one, so that i can have a uniform look, spacing wise, when i reattach them.
Sticky Wickett
#867 Posted : 18 November 2021 21:37:57
The attached photo shows the hinge fitted and the tube rear door operable. I decided to make all of the doors hinged and operable at this stage, to get a uniform look, even though 3 of them of will be glued shut.Blink
Sticky Wickett
#868 Posted : 18 November 2021 21:39:13
Torpedo tubes painted and doors fitted to 3 of them. There are lots more details to add before installation, but this is good starting point.
Sticky Wickett
#869 Posted : 18 November 2021 21:44:57
That concludes this update, see you next week for another instalment!Blink
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#870 Posted : 21 November 2021 08:48:09
Very nice work Phil, those hinges looked fiddly.Love Love
goddo
#871 Posted : 21 November 2021 11:15:28
That was a good find with the guy in Germany. You are doing a great job to make it all look so realistic.
Chris
#872 Posted : 21 November 2021 18:49:24
Bit like me - i was “collecting” the upgrades for my Deagostini Victory only to find new additions I had missed had ceased production. I contacted the chap and he said as “i was such a good customer” he would do a “one off” production for the additional parts.
So now i have a wonderful range of add on parts for my Victory and it would be a “crime” not to pick up the build.
Your build is outstanding. I have followed with you since the start and what you have produced is simple exceptional.
I have all the parts for that sub build and the sad fact is i will never get to build it, along with many ship models i bought for my “retirement”.
Just see it all ending up in the skip which is sad.
Your building is outstanding. Looking forward to your next update.
Tony
Sticky Wickett
#873 Posted : 25 November 2021 20:17:11
More progress was made on the torpedo tubes which i mentioned last week. Adding some finer details such as handles on the rear doors, adding etched numbers to each rear door as well as valve hand-wheels and extra pipework and levers. All painted, varnished then heavily pin-washed to pick out the details.
The attached photo shows tubes 1 & 3 completed and ready for fitting.
Sticky Wickett
#874 Posted : 25 November 2021 20:19:24
Tubes 1 & 3 fitted showing tube 1 with it's rear door in the open position so that i can show a torpedo being loaded.
Sticky Wickett
#875 Posted : 25 November 2021 20:21:19
Tubes 2 & 4 detailed, painted, varnished and pin-washed, ready for fitting.
Sticky Wickett
#876 Posted : 25 November 2021 20:21:56
Tubes 2 & 4 fitted.
Sticky Wickett
#877 Posted : 25 November 2021 20:22:35
All 4 tubes completed!
Sticky Wickett
#878 Posted : 25 November 2021 20:23:16
Sticky Wickett
#879 Posted : 25 November 2021 20:26:34
That concludes this update. Next week i'll be adding a few smaller details in and around the tubes before i then concentrate on the rear bulkhead, which includes making a set of steps.BigGrin
Phil W.
Kev the Modeller
#880 Posted : 25 November 2021 21:27:41
Excellent work as always Phil, really like that last photo, gives a real impression of the menacing side of a torpedo room!
Keep it coming! Cool ThumpUp
Kev
Per Ardua Ad Astra
Guest (26)
This page was generated in 0.821 seconds.
