Markwarren wrote:Just catching up on your latest instalments. Great work Phil, taking shape very nicely. Mark Thanks for looking in mark Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The kit detail to be removed of the fire wall and brace have now been removed and the ejector marks filled tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
There are two lubrication systems one for each side  the one on the driver`s side needed to be shortened tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Made a new gear lever from plastic rod and brass rod  then attachrd along with a lubrication tube also made from plastic rod and finished with some solder , i then added the secondary accelerator pedal to the gear box  Also made new steering lever as the kit ones where too small and the wrong shape tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The missing sirocco fan has arrived from shapeways tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Excellent work Phil, looking forward to your next instalment. Mark Regards Markwarren (Mark) Admin
Kev the Modeller wrote:Excellent work on those modifications Phil and looking good.
It seems you are seriously afflicted with the 'scratchbuilding' bug now, though I have to warn you that once bitten there is no known cure! You will never be able to build a kit straight out of the box anymore!
I know .... I've been trying to build something OOB for decades now and I still haven't managed it!!
Kev
Thanks Kev  ye i know what you mean i can`t remember the last time i built OOB  quite scary that Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Markwarren wrote:Excellent work Phil, looking forward to your next instalment. Mark Thanks Mark for looking in mate  over the weekend for the next one Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The new fans have arrived from shapeways  these will replace the kit ones which are incorrect for the King tiger  the one`s supplied are for the Panther  pic 1 the new ones correct for the K.T and pic 2 showing next to the kit one Regards Phil tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The bottom fuel tanks here showing the new fixing points and a fuel indicator made from scrap brass plasti card a resin bolt heads tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
the tool box here simple mod made new hinges and drilled the missing hole tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The kit radio operators seat tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Again shown next to the new one tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Escape hatch built up  but lacking the interior lock bar and tab  which i`m adding from strip tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Wow, Some excellent modifications being added to this build. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Wow, Some excellent modifications being added to this build. WTG Regards delboy271155 (Derek) Thanks Derek  for looking in and your comments  a lot more to come  stay tuned Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Top job Phil, really enjoying this build and have to say this is going to be museum quality when finished with all of that amazing detail being added. It looks as though you're not missing anything!
Looking forward to your next update already!
Kev
Per Ardua Ad Astra
Great work Phil, loving all the extra detail you are doing. Mark Regards Markwarren (Mark) Admin
Kev the Modeller wrote:Top job Phil, really enjoying this build and have to say this is going to be museum quality when finished with all of that amazing detail being added. It looks as though you're not missing anything!
Kev
Thanks Kev  well i don`t think i will be doing everything as my skill isn`t as good as Dave parker`s ,but it`ll be as near as i can get it mate  Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Guest (6)
