 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,736 Points: 17,360 Location: ipswich
Well, it's 99% finished. I say 99% as I'm going to add a thin red coach line along the ridge in the body sides, to go with the red carpet interior. Just a bit of added bling. It was an amazing build. Easily one of the best kits I've built even allowing for the annoying instructions that frequently tell you to assemble parts and then take them apart again (sometimes many) packs later. Everything fitted with no problems and as I mentioned in my build, just about the easiest body fitting I've come across. A matter of minutes to put it in place. Anyway, back to the Lotus 72... roymattblack attached the following image(s):
Roy, Thank you for sharing with us all. A stunning model and beautifully finished off. Well done sir. Chris
 Rank: Pro Groups: Registered
Joined: 22/02/2014 Posts: 201 Points: 589 Location: Big T
Very nice Roy. I'm still collecting the issues so your build is an inspiration. Your speed and quality should be made into an elixir for us sloooooow types. Thanks for sharing.
Very nice work Roy, that was a speedy build. Looks great. Mark Regards Markwarren (Mark) Admin
Very nice Roy. Have you had a go at the engine build yet? Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
That's a fabulous end result Roy, very nicely put together and a very speedy build too! I think the thin red coach line will add a nice touch and I too would like to see the display engine when it's finished?
Nice job!
Kev
Per Ardua Ad Astra
 Rank: Semipro Level 2  Groups: Registered
Joined: 03/06/2020 Posts: 86 Points: 247 Location: Lichfield
Nice job Roy,really impressive model.
