Bundle of Snakes - Charmer Options
mortyjeff
#1 Posted : 09 December 2021 21:06:12
Rank: Beginner Level 3
Spent a couple of days sorting out my version of the bundle of snakes.
There are as many ways to do this as there are modelers willing to try.
mortyjeff attached the following image(s):
Eagle
#2 Posted : 10 December 2021 13:53:34
Red Medal: Red Medal
Did you modify your pipe lengths for the #3 and #6 to crossover?
mortyjeff
#3 Posted : 10 December 2021 17:24:38
Yes,
Exhaust 2,3,6,7 (see attached diagram) cross over to the opposite collector.
The dimension between the original location and the new was 9mm for me.
I 3d printed some 9mm long X 6.731 dia (.265 in) spacers, some .265 dia 90 deg elbows, and crossed my fingers. Blink
Exhausts 1,4,5,8 are not modified.
The only issue is the space between the Carb heat shield and the collector position, not a lot of room there.
JOHN-GT40
#4 Posted : 11 December 2021 22:15:55
Looking really nice
i will be getting a company to custom make a
full set of snakes x 8
2 x silencers
heat shield for silencers
2 x new set of tail pipes
for my FORD GT40
in regards to deagostini exhaust system, i am highly disappointed
as this is a major feature on the GT40
kind regards
JOHN-GT40
mortyjeff
#5 Posted : 12 December 2021 16:55:44
Thank you for the kind comments,
They mean quite a bit coming from the more experienced.
JeffBigGrin
mortyjeff
#6 Posted : 11 February 2022 22:34:18
Not to worry Modelers,
There is plenty of room between the Exhaust Pipes and the Rear Sway Bar for mods.
This page was generated in 0.756 seconds.
