13 Pages «<10111213>
Micks 1/200 battleship bismarck Options
#221 Posted : 31 October 2021 16:32:04
Issue 129
Here it's just fit the gun to the deck and add the barrel elevation gearbox to it cheers mick. BigGrin
#222 Posted : 31 October 2021 16:41:04
Issue 130
Here we fit the gun rotation motor to the main gun and start on the main deck handrail first 4 sections, at this point the cat attacked it and ripped the forward handrail off twisting it through full 180 degrees I managed to repair it and get it back on, finally few shots where we at, weathering one side the hull with salt stains dirt and rust. Cheers mick. BigGrin
Kev the Modeller
#223 Posted : 31 October 2021 23:24:57
Very nice work on those fiddly railings Mick, looking good and boy is this an impressive sized beast? I think you're gonna need a bigger house! Blink Cool ThumpUp
Kev
Per Ardua Ad Astra
#224 Posted : 03 November 2021 18:51:24
Mick
You are close to the finish now.
Have you seen the display stand and the control box for this one? Its been posted up on the German build site.
The control box looks well impressive.
Tony
#225 Posted : 04 November 2021 11:39:40
Hi Kev and Tony thanks for your comments much appreciated, yes seen the display stand and remote for this 44 buttons I counted on the remote and glad the battery's and sound are all built into the stand, also noticed the 32 steps on rigging to that going to be fun.only 10 issues to the end now. cheers mick. BigGrin
#226 Posted : 05 November 2021 13:47:12
Wow, this has certainly moved on since I last looked in Mick and what a superb job you've done with her.... Drool Drool Drool .. All credit to your skills and patience.....Cool Cool
#227 Posted : 05 November 2021 14:35:13
Very nice work Mick BigGrin she is a monster Cool but very coolCool
Regards PhilCool
#228 Posted : 06 November 2021 15:01:31
Beginning to think it might be time to start mine.
Having stored all the packs so far they are taking up a massive amount of space.
Wonder what they might offer when this one is complete?
Tony
#229 Posted : 07 November 2021 22:19:34
Hi Mick
Have you seen this video?
https://youtu.be/OkW_ZM3LCcA
Tony
#230 Posted : 09 November 2021 16:31:58
Coming on nicely Mick.
Cool Cool Cool Cool Cool
Very impressive.
tubab
#231 Posted : 12 December 2021 01:54:56
Rank: Amateur Level 1
Hi all builders, I am now up to part 138 and have found a couple of potential problems one of which I hope has been resolved. The first problem was the touch switch which worked fine when not assembled but when in place it refused to react. My skin is tough so might be the cause, Hachette are sending a replacement and think the switch is faulty. The second point is that we have 4 cables going from the support to the Bismarck, two black wires and two red. The readings I get from the terminals suggests that all is not well but we lack information on what to expect. Can somebody who has reached this stage and has a working model please measure the voltages and publish them, it would be a useful trouble shooter. Many thanks Tony.
#232 Posted : 12 December 2021 11:40:58
Hi I have only got to issue 134, think be after xmas before get up to 138 mine did pass its electrical in issue 133 ,think probably going to have to wait till get remote in issue 140 to see how things work,as you say there's no information on what voltage should be coming from the wires you mention anyway,cheers mick BigGrin
tubab
#233 Posted : 12 December 2021 12:07:40
Hi Mick, There's a small circuit board that fits in the support that contains the speaker, it takes power from the batteries that are housed in the other support and supplies two pairs of feeds to the model, ie two black wires and two red. All my other electrics in the model itself are fine. The support itself is a bit flimsy for the weight of the model, I think they could have done a better job of it.
Regards Tony
BTW The only voltage I am getting is on one red wire and is Minus 6.5v hence my concern.as it supplies power to all the units in the model.Hopefully when I get the replacement power touch switch it will include the circuit board as well.
#234 Posted : 13 January 2022 13:52:56
Hi thanks to all who looked in and left comments much appreciated.
Issue 131
More electrics fitted in this issue the fourth circuit board and the pick up connectors from ship to stand and couple magnet contact plates and cables. Cheers mick. BigGrin
#235 Posted : 13 January 2022 14:11:29
Issue 132
Alot to do in this one starting with the anchor chain guide a few details around the fourth main gun barbette then the stern flag staff and light, more railing and the 2 quadruple aa guns you will need to remove the guns fitted in issue 106 as these are in the wrong place and glue them in platform below and fit the quadruple on the top platform. Then 2 aa guns on the funnel platform, then build up the second plane. Cheers mick. BigGrin
#236 Posted : 13 January 2022 14:15:38
#237 Posted : 13 January 2022 14:23:34
Issue 133
Here we get another circuit board to fit under the rear deck then connect everything up and do a full electrics test on everything mine all worked as should, then just 2 more bits of handrail to fit. Cheers mick. BigGrin
#238 Posted : 13 January 2022 15:29:06
Issue 134
First of all we assemble the 2 cranes, then assemble and fit the 4 booms and the propeller protection, then glue in the safety rails there are 20 of these to glue in behind the main handrail. Then glue in 6 more bits of main handrail, then bend up and fit the catapult platforms, then fit the catapults in we got in issue 4. Then bend and fit the catapult cover, they do glue the 2 planes in now but I'm leaving mine till the rigging is done in last issue as they are rather vulnerable at the moment. Cheers mick. BigGrin
#239 Posted : 13 January 2022 15:36:13
Hi I'll upload the rest another day as site being a pita keep getting server error all the time cheers mick.
#240 Posted : 13 January 2022 17:09:52
Guest (11)
This page was generated in 1.954 seconds.
