Issue 57 Querry Options
Gan_Javi
#1 Posted : 03 October 2011 18:44:58
I bought issue 57 and found the same issue as everyone else. The 1.5x6 parts are all 240mm instead of 300. I have a feeling that ALL the parts will be like that so my question. Can I use those 5x240 ones even if I have to glue some together, or MUST they be 300?
And if I can glue them, are they visible or completely covered?
Francois
willie
#2 Posted : 03 October 2011 19:33:12
these planks are for the cross beams aft for the deck LONGEST 120MM SHORT IS ABOUT 110MM CUT RIGHT AND YOU WILL HAVE A SPARE PLANK LEFT TOTAL OF 8 BEAMS TO CUT FOR THE LAST 4 FRAMES IN THE CABIN check in general discussion ,issue 57 parts incrrect length ,posts 25 to 28
z8000783
#3 Posted : 03 October 2011 21:59:59
Groups: Unapproved
Sent off for replacement which arrived and all correct although take note of the what others have said about the actual sizes needed.
My view is though, do what it says on the tin and then everyone is happy.
John
#4 Posted : 03 October 2011 22:06:58
As John says, the 240mm length is adequate for the task these strips are used for (poop deack beams), and replacement is not necessary.
This page was generated in 0.169 seconds.
