52 Pages «<4849505152>
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#981 Posted : 27 January 2022 21:10:28
Looking from another view.
Sticky Wickett
#982 Posted : 27 January 2022 21:15:33
I then took a full length photo of the port side [left side] of the model, just to show how large it is, measuring 1.4 meters in length [4 feet 7 inches] and it weighs a fair bit too; pushing 5-7 Kg's i reckon!Blink
Sticky Wickett
#983 Posted : 27 January 2022 21:17:09
I then fitted the fore-planes. Again i will 'sit' with the algae effect and see if i need to tone it down or not.
Sticky Wickett
#984 Posted : 27 January 2022 21:17:44
Looking at the fore-planes from above.
Sticky Wickett
#985 Posted : 27 January 2022 21:18:40
Another full length photo, this time showing the starboard side.
Sticky Wickett
#986 Posted : 27 January 2022 21:20:45
I then turned my attention to adding details on the casing. Seen here are cleats and shackle points.
Sticky Wickett
#987 Posted : 27 January 2022 21:21:29
Accommodation space hatch.
Sticky Wickett
#988 Posted : 27 January 2022 21:23:04
This view shows the aft end of the U-boat with the navigation light housing fitted along with two stanchions which will support the radio antennae wires
Sticky Wickett
#989 Posted : 27 January 2022 21:24:42
Looking from another angle.
Sticky Wickett
#990 Posted : 27 January 2022 21:26:07
Singular aft cleat and 4 shackle points fitted.
Sticky Wickett
#991 Posted : 27 January 2022 21:27:44
Rear view showing cleat.
Sticky Wickett
#992 Posted : 27 January 2022 21:28:46
Rear view of aft navigation light and radio antennae stanchions.
Sticky Wickett
#993 Posted : 27 January 2022 21:31:10
That concludes this update, more to follow next week!
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#994 Posted : 28 January 2022 09:24:30
Excellent build, just looks amazing.Love Love
Sticky Wickett
#995 Posted : 03 February 2022 22:18:36
This week i concentrated on making the guard rails that run each side of the casing. I had to do a bit of research on this as the design of these guard rails changed quite a lot throughout WWII. I also referenced photos of U995 and U230 and found them the same, so based my design on that.
I used 0.8mm O/D brass micro tube and brass connecting pieces. Not many photos this week considering the amount if work involved.
Sticky Wickett
#996 Posted : 03 February 2022 22:21:38
The guard rails have not been glued or painted, just fixed together. I still have a bit more 'pushing and pulling' to make sure everything looks right before i apply glue to every joint, then undercoat, weather and fit.
Sticky Wickett
#997 Posted : 03 February 2022 22:24:57
This photo shows the smaller guard rails, located forward of the main sets. These will be connected to the aft guard rails via copper wire; like the real thing, these connecting wires could be removed when the U-boat was alongside and gangways were fitted from the casing to the jetty.
Sticky Wickett
#998 Posted : 03 February 2022 22:26:47
That concludes this update, more content to follow next week.
Phil W.
Kev the Modeller
#999 Posted : 05 February 2022 22:43:19
Excellent work as always Phil, loving all of your weathering on the hull, it really looks as if it's spent many a day beneath the Atlantic hunting the merchant shipping in 'torpedo alley'! Very nice indeed.
As you're nearing the finish line now on this epic build Phil, have you given any thought as to what your next project might be, if any?
Kev
Per Ardua Ad Astra
goddo
#1000 Posted : 05 February 2022 23:27:13
Stunning work, Phil.
Fantastic attention to detail and that weathering is superb.
Chris
Guest (24)
This page was generated in 0.678 seconds.
