3 Pages <123
OcCre Santisima Trinidad 1:90 1st Rate Ship of the Line Options
#41 Posted : 01 April 2021 10:54:27
Hi looking good Gray, I prefer your second deck planking to ,cheers mick.BigGrin
Nytetrain
#42 Posted : 01 April 2021 11:27:50
Nice job on the deck Gray. I agree the 4' stagger looks much more realistic. Love watching you guys do the wooden ship builds. Awesome work.
Best Regards,
Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator
Finished builds: DeAgostini Toyota 2000GT
In the Stash: Losing count...
goddo
#43 Posted : 01 April 2021 14:55:09
Hi Gray,
Yep, I agree with the guys above. The second version of decking looks much more realistic.
Chris
CaptnBirdseye
#44 Posted : 30 January 2022 17:22:25
Rank: Superelite
Well, it's been a while so i thought i had better update this diary!
Once the lower deck was complete it was time to fit the upper deck. This was then planked, stained and trenailed as per the lower deck.
CaptnBirdseye
#45 Posted : 30 January 2022 17:30:46
Rank: Superelite
The Bulwarks are fitted next, but you actually start from the top working downwards Confused
This presents its own problems, like how do you get the upper bulwark to fit along the edge of the top deck? In the end i glued some temporary tabs underneath the top deck, which alowed the bulwarks to sit at the right height. Once one side was glued in place, it was repeated for the other.
CaptnBirdseye
#46 Posted : 30 January 2022 17:46:00
Rank: Superelite
Each side has three rows of bulkarks, which terminate at the notch on each bulwark. As each row is fitted, 15mm squares are cut and glued in place behind each gunport. Some of these can be a bit of a pain to get in place. Also because of the bulkheads, some of these will need to butt up against them.
CaptnBirdseye
#47 Posted : 30 January 2022 17:56:30
Rank: Superelite
Once all of the bulwarks are in place, it is time to sand everything down, ready for planking Scared
I needed something that would alow me to turn the skeleton upside down without damaging the top bulwark. As luck would have it, i had just recently replaced our home printer and the polystyrene that came with it was just the right size for the hull to sit in ThumpUp Result!
I also added balsa to the bow and stern to help with the lay of the planking.
goddo
#48 Posted : 30 January 2022 18:00:28
A very nice update on your build, Graham
This is my next kit so following this closely.
Well done and keep it coming
Chris
John Passmore
#49 Posted : 01 February 2022 04:43:32
Publisher Medal: Featured Build of the MonthOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Coming along really nicely Gray.
Love the way you've planked the decks...BigGrin
JohnP
CaptnBirdseye
#50 Posted : 01 February 2022 13:01:32
Rank: Superelite
BigGrin Thanks for looking in guys, and your comments. Always appreciated ThumpUp
Gibbo
#51 Posted : 01 February 2022 17:18:22
That's looking good, nice to another ship on the go.
Silent_Running
#52 Posted : 02 February 2022 20:00:42
The Stain looks fantastic Gray, what stain is it, if you don’t mind me asking. She’s looking great, keep up the good work.
Glenn
#53 Posted : 02 February 2022 20:53:22
Good steady progress Gray.... look forward to seeing how she progresses.....Cool Cool Cool
CaptnBirdseye
#54 Posted : 02 February 2022 21:37:37
Rank: Superelite
BigGrin Gibbo, Glenn, Alan, thanks for looking in guys ThumpUp
Glenn, the stain is just Wilco's own Danish Oil. Only thing is, because it is just 'wiped on and allowed t dry in', it's easy to catch when sanding so might need another coat yet!
CaptnBirdseye
#55 Posted : 02 February 2022 21:44:30
Rank: Superelite
Today's small update involves planking below the transom.
Due to the curve below the transom, i had to temporarily use pins to hold the planks on the lower counter in place while the glue dries. When cured, i will sand to shape.
While waiting for that, i thought i would skip forward a bit in the instructions. I had read that once the upper planking was in place, the false gunports need painting black. As many have said, this has disaster written all over it, as the posibility of getting paint on the resulting planks is waaaayyyyy to easy!
So i used some Tamiya X1 Black acrylic to 'black out' the ports before fitting the planks.
I've found a noticeable drawback with the Amati Keel Clamp, shown in the last picture below. When trying to clamp it to my worktable, the front end has a habit of 'lifting'. So much so that i couldn't use it easily on my workbench so had to adapt my computer table Huh
Gibbo
#56 Posted : 03 February 2022 18:03:36
Smart move on the gunports, looks great.
goddo
#57 Posted : 03 February 2022 22:18:38
Smart thinking on the gun port painting, Graham.
Hopefully a lot of these tips are sinking in for when I start on mine.
Well done.
Chris
3 Pages <123
