I've decided to pull this one out of my stash where it's been hiding for around 7-8 years. I'm aware it's very innacurate in places and to make things worse, the body is quite warped and one screen pillar broken. That aside, it's apparently a hard kit to find and strangely, it fetches a fair price nowadays. I'm not going to go mad and correct the 'wrong' bits unless it's pretty straightforward. After the twin Porsche aggro, I want something fairly simple to do. I'll add to the engine and interior, and I'm going to make it in a race scheme - undecided which one as yet. roymattblack attached the following image(s):
Hi Roy, What`s a warped body and broken pillar to a Maestro of car building. Good Luck, will be watching. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Kind words Derek. Many thanks. Here's the car I'm going to base the model on... roymattblack attached the following image(s):
Where would the fun be with out a little challenge.  Very nice kit and I’m sure you you’ll do your usual great job on it even with your eyes closed. Mark Regards Markwarren (Mark) Admin
Thanks for looking in chaps. Well, I really have no great aspirations about this one. It's no better than a 1/32 Airfix kit, just bigger. NOTHING has any real detail. I didn't bother adding anything to the front suspension etc as it will never be seen anyway. The engine - almost funny. A simple V6 plastic blob. NO iconic top oil filters, distributors mounted at the front - WRONG - I moved them to the rear. No ignition leads, fuel linwes, no pipe work - the list goes on. I've added and altered where required so the eventually, the engine might look a bit more presentable. We shall see... roymattblack attached the following image(s):
A bit more on this one. I've added a lot of wiring etc and now fitted the back firewall. The wiring will be fed through the side firewalls later on. roymattblack attached the following image(s):
On we go... The basic plasticky interior has now been painted, carpeted and the seat parts trimmed in real leather and the inner 'tub' fixed to the floor/chassis section. I tested the body fit and I have to say that it's excellent. Surprising for a pretty basic old Revell kit. On we go... roymattblack attached the following image(s):
