Yes, I'm a glutton for punishment. This one has been hiding in a box for ages. I thought I'd give it a go. It's a Ferrari 250 GT SWB (I think) - 1/12 scale resin. It's very detailed - LOADS of engine/chassis/interior detail. However, the body is a bit worse for wear. Added to that, I have no instructions and no idea who manufactured the kit. Anyway, first order of the day is to attempt to put the jigsaw puzzle together. roymattblack attached the following image(s):
 Rank: Semipro Level 2  Groups: Registered
Joined: 03/06/2020 Posts: 86 Points: 247 Location: Lichfield
Good luck with that Roy but I have a sneaky feeling it’ll turn out great 👍🏻
GlynD wrote:Good luck with that Roy but I have a sneaky feeling it’ll turn out great 👍🏻 Thanks for that Glyn. Well, after a good 3 hours of head scratching, Superglue and epoxy, I have a body. STILL a huge amount of filling, sanding, priming and paint before anything else. The yellow lines are the breaks/glued parts. A very LONG way to go and I really STILL need to track down the kit manufacturers to get some kit instructions. I have four BIG bags of parts - many in etch and metal - and NO idea where they go. roymattblack attached the following image(s):
After gluing and filling last night, This morning, lots of sanding and then a coat of primer to show up the dodgy areas still needing attention. Fairly pleased so far though. roymattblack attached the following image(s):
Nice work Roy, it is like watching an episode of Car SOS. Mark Regards Markwarren (Mark) Admin
Top build Roy, love watching your builds come together Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks for peeping in and commenting chaps. After a few days drying time for the primer, the body had a final sanding with 1000 grit and 3 light coats of yellow followed by a final wet-coat. Now to leave it at least 24 hours before a bit of buffing. roymattblack attached the following image(s):
Joined: 25/12/2019 Posts: 218 Points: 659 Location: Manhattan, NY
Nice repair work Roy! That should be a good looking model when complete -Dustin
“Details make perfection, and perfection is not a detail.” -Leonardo Da Vinci
Currently Building: Porsche 2.7 RS
Currently Collecting Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
Many thanks for looking in Dustin. I've realised this model isn't 1/12 scale at all - it's 1/16. I'm also currently working on a Revell 1/12 275GT and it's a LOT bigger. Anyway - the main engine parts are now assembled - terrible, rough, ill-fitting castings - and I've added the missing wiring and fuel lines. WHY do I keep torturing myself with these awful projects??? roymattblack attached the following image(s):
