Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
Progressing very nicely. Nice work Steve. Mark Regards Markwarren (Mark) Admin
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,494 Points: 4,394 Location: Essex
Cheers Mark👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Joined: 27/11/2021 Posts: 2 Points: 6 Location: Novi, MI
Greetings, I am at the same stage as you in this thread. Question for you. Are you able to compress the shock absorber assembly? I'm wondering if I've done something wrong but the springs seem a bit stiff. Maybe once the auto is fully assembled?
TTom wrote:Greetings, I am at the same stage as you in this thread. Question for you. Are you able to compress the shock absorber assembly? I'm wondering if I've done something wrong but the springs seem a bit stiff. Maybe once the auto is fully assembled? Yes they are stiff. But as long as they move then all is OK. I can only assume the reason for the high stiffness is due to the model being mainly metal hence will be quite heavy when finished Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stages 11-14 here now. Unsure whether to build this now or wait for a couple of more packs and build the engine in one go. 🤔 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stages 15-18 here now. Still not done the last pack! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 11 done. I decided not to put this wheel on yet as apparently they both have to come off again at some point. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,770 Points: 17,462 Location: ipswich
Another great update here. The 'wheel removal later' bit rings bells from my Mazda Cosmo build. Two steps forward, one step back. A fun and highly detailed kit though. Looking forward to seeing more of this one.
Cheers👍 Stage 12 done now. Gearbox Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Coming on nicely Steve. Mark Regards Markwarren (Mark) Admin
Thanks Mark👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 13 done. Engine started on. This is a big heavy lump, all made of metal!👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Keep it coming - I'm following along.
Glad you're enjoying it Roy!👍 Stage 14 and pack 4 finished now. Heads and rocker covers fitted. I have packs 5 and 6 here too so will be more coming soon Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 5 now. Stage 15, intake and supercharger. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 16. HT leads, distributor and water pump. I thought this stage was going to be a bit fiddly but it was relatively easy👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 17, fead system Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nice progress Steve. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Another nice update Steve. It's clearly going to be a great model.
Cheers fellas👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Guest (7)
