GT40 Custom build PACK 4 Options
#1 Posted : 20 March 2022 15:44:19
This pack contains parts 10, 11, 12 & 13
PART 10:
This is the covering for the passenger seat previously started with part 9.
Fit the covering as per the instructions. A very straight forward process.
PART 11:
These parts will ensble you to assemble the two seats and centre console.
The console was covered in thin black leather using heavy duty double sided tape.
Once this is done, all the seat parts can then be put together to form one unit.
Put the assembly safely to one side for now.
PART 12:
The outer door panel and light for the other side of the car.
As before, the decals were removed and the door panel repainted the correct dark blue.
PART 13:
These parts are for the window, latch and hinge of the passenger door.
All of these parts can be assembled as per the driver door.
This page was generated in 0.326 seconds.
