1/12 ABC Brianza Alfa GTA 1300 Options
#1 Posted : 23 March 2022 14:26:52
The 'other' kit I'm going to start along with the big Pocher, so that will be two Alfa's on the go!
This is a 1/12 kerbside kit of the 1972 Alfa GTA that won umpteen races in its day.
It's from ABC Brianza and for some odd reason, these simple kitas fetch silly money.
There are literally about 50 parts to it.
Very cleanly moulded body shell which needed minimal clean up around the bottom, the arches and the window openings.
After a good soapy scrub and dry it's had a fine rub with 1000 grit and it's now in primer.
With luck, this will be a simple build after the previous broken nightmare.LOL LOL LOL
GlynD
#2 Posted : 23 March 2022 20:14:19
Rank: Semipro Level 2
After the great job you did with the 250 SWB I’m sure this will be great, any ideas on paint and livery Roy.
#3 Posted : 24 March 2022 13:50:57
This is the scheme I'm going to do...BigGrin
#4 Posted : 27 March 2022 09:38:24
After masking the front end of the body, it's now had 5-6 coats of red, 1000 grit sanding between coats.
Masking removed so I can now mask it the other way around to paint the white front section.
On we go...BigGrin
andali15
#5 Posted : 27 March 2022 11:43:01
All looking good Roy. Your skills are endless. Watching to see this come together. Andy
kpnuts
#6 Posted : 27 March 2022 12:24:50
Great start on this one roy
#7 Posted : 03 April 2022 11:48:20
After more masking, the white section at the front has been painted.
The kit actually supplies decals for this but I prefer paint.
Polishing needed when it's fully dry - another few days.BigGrin
#8 Posted : 03 April 2022 13:42:47
Looking very nice Roy. ThumpUp
kpnuts
#9 Posted : 03 April 2022 13:53:50
Looking good Roy.
#10 Posted : 01 May 2022 13:17:17
This has been sitting to one side just lately but I'm back on it again now.
The side window frames and glazing was fairly easy as it's all pretty much flat.
The front and rear were a different kettle of fish.
The etched frames are flat as supplied and have be bent to fit. Then the thin clear plastic is fixed to the inside of the frame, and then trimmed around.
Then the fun began.
Yet another un-symmetrical body so that no matter what you try, the etched metal frame of the window actually only 'fits where it touches'.
It was in the end, a compromise.
To make the frames fit properly, they would need to be twisted from opposite corners.
OK, easy enough but then it creates huge creases and wrinkles in the glazing.
The only option was to have the front and rear screens 'approximately' in the right place.
Not too bad in the end but not really satisfactory.
Blasted obscure resin kits!Laugh
#11 Posted : 01 May 2022 15:53:22
A tad more this afternoon.
Assorted lights and grilles now in place.
Wheels/tyres next, then put the bits together. Decals after that.
On the home straight now.BigGrin
kpnuts
#12 Posted : 01 May 2022 19:04:19
#13 Posted : 05 May 2022 08:14:49
Thanks Ken.
Almost there - a few details and decals...
This page was generated in 0.207 seconds.
