Hi Derek, Very nice work neat too, It does take a lot of patience to complete the wing and there are some tricky parts to come such as the undercarriage posts and wing housing. Well done Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote:Hi Derek,
Well done
Trev Hi Trev, Thanks for looking in. Have seen the tricky parts you mention and will be dry fitting a lot to make sure it all comes together correctly. Thanks for the heads up.  Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,416 Points: 22,558 Location: Northamptonshire, England
Cracking work Derek.  That is some size model. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Cracking work Derek.  That is some size model. Mark Hi Mark, Thanks for looking in. Its a kit that needs loads of accuracy when assembling the basic frames so that the panelling fits when you get to that stage, with the least amount of fettling. Below are some of the stats for the kit to show the size: 1:12 scale Model Length 760mm. Wingspan 935mm Functioning items: Variable pitch propeller. Operable Ailerons, Elevator, Rudder, sliding Canopy and opening pilot access door.(If I don`t make any errors  ) Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Gone off line with this a bit as per the instructions order. Taken a break from the plating, (finger and wrist tendons need a break) and moved onto the wood strips on the fuselage to shape up for the plates on the fuselage. Haven't pictured it step by step, but have a full pic of each side. Now have lots of gentle sanding to do, so I can get the best possible shape on the fuselage ready for plating. Even at this point the jury is still out as to whether this will finish up in Camo or steal finish. That`s still down to how the overall plating etc goes. If there`s lots of gaps and filling is required then it`s Camo finish, no/minimal gaps then it could still be steal finish. My preference is the steal finish, but only time will tell. Attached are two pics of the fuselage with the added strip wood. Happy modelling and take care. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, Thanks for posting your progress to show us all, with all the bits of wood in place and ready for plating, it is so important to sand them flat to look correct. Don't forget that you will need a Helix Non-skid (rubber back) ruler from W. H. Smiths when you roll down rivets on the metal plates. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice work Derek, steal finish is what I would do as well, just love the look of this model. Mark Regards Markwarren (Mark) Admin
