GT40 Custom build PACK 5 Options
#1 Posted : 03 April 2022 12:51:49
This pack contains parts 14, 15, 16 & 17
PART 14:
The parts here are to construct the interior of the passenger (co-driver) door.
As with the drivers door, these parts are easily assembled after first painting them satin black. Assembly is very straight forward.
PART 15:
These parts are to complete the interior of the passenger door.
Again, assembly is very easy after first painting the parts satin black.
PART 16:
This stage provides the parts for the main interior floor panel.
As before, this should be painted satin black to remove the 'plastic' look of the part.
The seats will be fitted at as later stage.
PART 17:
The right rear engine bay floor panel.
Once again, paint this part satin black although depending on which version of the real car you may be working from, it could also be painted alumuminium silver.
Assembly is simple, following the instructions.
This page was generated in 0.425 seconds.
