51 Pages <1234>»
DaDokta`s Build Options
Gerrit
#21 Posted : 05 October 2011 06:48:55
Looking superb
Gerrit
#22 Posted : 05 October 2011 09:34:50
Very nice clean buildBigGrin Cool
DaDokta
#23 Posted : 02 December 2011 22:48:38
It`s been a long time since my last post. But the fairing of the hull was very tricky (also family and job not allowing much time for the build).
I had to reduce or build up almost every rib at some section - but now i`m happy with the result.
In the meantime i also started the launch and the planking of the gallery supports - i`ll post those pictures in the next days (and hope someone is interested despite the fact that i`m so far behind the most of you!)
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#24 Posted : 02 December 2011 23:30:25
Good StuffBigGrin Cool
#25 Posted : 03 December 2011 02:21:40
BigGrin Hi DaDokta
your preperation is excelent im impresed with the time you have taken here to get it right it can save you many headaches in the future of the build as others have found out with certain ribs not seating properly.And remember your not behind anyone your just catching up with the other builders on hereLOL , plus you have the option of perusing all the build diarys on here to see the problems others have encountered on the build and the actions taken to solve them.
#26 Posted : 03 December 2011 11:02:42
Hi DaDokta, nice clean build keep going it's looking good and heed the advice of the experts, saves you alot of grief later in the build.
#27 Posted : 04 December 2011 23:37:03
Very nice jobBigGrin Cool
Atholm
#28 Posted : 05 December 2011 14:32:12
Things are taking shape. Keep up the good work.
Happy building.
Athol
DaDokta
#29 Posted : 05 December 2011 19:38:20
Thanks for your nice comments!
This time i need your help,cause i don`t know if i`m doing the paintwork right.
Now my questions:
1. I started with a coat of white primer - then sanding - next coat of white primer - then painting.
I had the feeling, that the primer slightly changed the shade of the yellow ocre.
Do you really need the priming? Or could you just sand the hull and then paint it? Or maybe paint it in the colour you want - then sand it down again - and put on a second coat of paint.
Also i`m afraid that the lots of coats make the structure of the wood unvisible - i wouldn`t like to have it look like a plastic model.
2. Can i leave the hull now as it is - or should i put a coat of varnish on it. And if yes - i`ve got matt varnish, satin matt varnish and flat matt varnish (whatever the difference might be :)) - so which one should i use?
I really would appreciate your advice. Thanks guys.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#30 Posted : 20 December 2011 14:10:54
Any ideas anyone???
Well then i guess i will have to try and error :)
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#31 Posted : 20 December 2011 14:21:29
Hi ,I like to use primer, and I think your use of same has achieved a very good result and the yellow colour looks right to me,avery nice build sirBigGrin Cool
DaDokta
#32 Posted : 20 December 2011 14:54:41
Thanks, MWG.
May i ask again if i should put a coat of varnish on the hull (matt or satin-matt?) or leave it as it is?
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#33 Posted : 20 December 2011 15:04:02
Hi, yes a coat of water based matt varnish would seal your work nicelyBigGrin
DaDokta
#34 Posted : 20 December 2011 21:15:39
Thank you very much for your help, MWG.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#35 Posted : 28 December 2011 10:39:39
So here`s an update with some pictures of my launch.
I modified it a little bit, cause i wanted it to look more like the one, which is standing in portsmouth.
So now for the planking of the Big one :)
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#36 Posted : 28 December 2011 22:38:01
Spot on!! very nice jobBigGrin
Mike
Foz
#37 Posted : 28 December 2011 23:05:28
Nice looking launch you have there. keep up the good work.
Foz
#38 Posted : 28 December 2011 23:09:39
BigGrin Spot on with the launch
#39 Posted : 29 December 2011 00:17:45
Very nice launch, well done BigGrin
riff-raff
#40 Posted : 29 December 2011 11:17:47
A good solid looking start mate BigGrin
Built:
Guest (13)
51 Pages <1234>»
This page was generated in 0.386 seconds.
