GT40 Custom build PACK 6 Options
#1 Posted : 24 April 2022 14:44:46
This pack contains parts 18, 19, 20 & 21
PART 18:
This part is for the rear left chassis floor panel.
As with the previous part it was painted satin black before being fitted.
PART 19:
The parts included here are for the fuel lines, door-step side covers and fire extinguisher.
The fuel line parts were painted satin black before fitting, to match the car I am modelling.
The silver side panels were fixed in place as per the kit instructions.
The fire extinguisher was assembled and the join filled and sanded smooth before repainting the extinguisher bright red.
Detail painting was added and a correct fire extinguisher decal applied.
PART 20:
This part is for the interior rear wall and is used at the next assembly stage.
PART 21:
The parts here are for the seat belts, interior cubby box and the coil.
Using the interior rear wall - part 20 - the cubby box and seat belts were fitted after the wall and box were painted satin black.
The coil was discarded in favour of a more realistic resin part which was fitted complete with a mounting bracket, low tension leads and a red HT lead.
This page was generated in 0.191 seconds.
