5 Pages <1234>»
Malc's Pocher Fiat F2 Options
#21 Posted : 23 March 2022 09:52:38
Cracking work there.
Loving all the extra bits you're adding...Love
Kev the Modeller
#22 Posted : 13 April 2022 20:36:24
Lovely work as always Malc, to your usual very high standard and always very neat and tidy too! Looking very realistic and with your added extras you are moving this model up to another level.
Very well done. Loving your home made engine jig as well - simple, but a very effective and practical solution! Cool ThumpUp
Kev
Per Ardua Ad Astra
kpnuts
#23 Posted : 13 April 2022 22:53:41
What a great start, will be watching.
#24 Posted : 15 April 2022 10:38:26
Just catching up Malc, very nice work as usual. Love Love Drool Drool
#25 Posted : 15 April 2022 17:13:53
That engine looks first class, WTG.
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
Looking forward to the next update.Drool Drool
RM1
#26 Posted : 26 April 2022 15:14:04
Thanks for looking in Guys, and all the encouraging comments.BigGrin
I've finished a lot of the engine parts and been doing some trial fitting. The oil piping runs up into the tank attached behind the "dashboard".
RM1
#27 Posted : 26 April 2022 15:20:36
The original hosing for the water cooling had perished so I used heat shrink over a wooden dowel to make the parts. There's still the "S" piece to the radiator to form and I'm putting copper pipes from the lower cylinder inlet flanges to the radiator.
RM1
#28 Posted : 26 April 2022 15:25:53
The clutch is exposed to the elements ! and seems to be a spring loaded piece that is retracted off the back of the Flywheel assembly by the conical clutch ring. There's no spring shown in the kit so I'll wind a wire for some extra detail.
RM1
#29 Posted : 26 April 2022 15:28:13
The bonnet in place BigGrin
#30 Posted : 26 April 2022 17:56:44
A lovely looking build there. Keep it coming. I'm loving the added details.
#31 Posted : 29 April 2022 15:15:36
Wow, are you sure that is not the real car. You are doing a stunning job Malc.Love Love Drool Drool
kpnuts
#32 Posted : 29 April 2022 15:21:11
Thats incredible, looks amazing.
Kev the Modeller
#33 Posted : 04 May 2022 19:16:03
Excellent work all round Malc, beautifully put together and building up into a real museum piece.
Stunning work, very well done! Drool ThumpUp
Kev
Per Ardua Ad Astra
RM1
#34 Posted : 13 June 2022 15:41:57
Thanks for all the comments guys. BigGrin
I've been a bit slack on this build but managed to get some work done on the floorboards. I've used a self adhesive sheet of wood veneer and cut strips for the planks following the various widths of the wood effect on the plastic floor and dashboard. There are a couple of Brass ferules that will fit around the bosses to replicate the instruments. I finished it with a light coat of a dark oak varnish but not enough for a gloss finish.
Malc.
#35 Posted : 13 June 2022 16:36:03
Looks great. MUCH better with a real wood floor.BigGrin
#36 Posted : 17 June 2022 12:32:10
That is very impressive.Love Love Love Just finishes it off beautifully.
RM1
#37 Posted : 17 June 2022 15:40:08
Thanks, Mark, Roy. The wood makes a great difference. Very pleased with the result.BigGrin
Malc.
RM1
#38 Posted : 02 August 2022 15:38:40
The exhaust is pretty basic but forming the brackets to hold the main pipe at the correct angle was a little tricky. I haven't decided on the paint finish for the pipes yet.
Malc.
RM1
#39 Posted : 03 August 2022 12:30:33
Got the gearbox/transmission section completed and can now start on the final assembly of the chassis. BigGrin
RM1
#40 Posted : 03 August 2022 12:36:56
The exposed clutch seems to be a block pushed up against the end of the flywheel and retracted by a conical slip ring. The linkage to retract the clutch ring has been added and I've made a simple spring by winding copper coated wire.
5 Pages <1234>»
