How to choose a non battery power mod for GT40? Options
Eagle
#1 Posted : 04 May 2022 22:33:30
Red Medal: Red Medal
I'd like to eliminate the battery compartment and use USB power or power mod for theGT40, any advice appreciated. Pack 23 is arriving tomorrow, I called Model Space to ask for pack 24 but I was told it was on backorder and to call in two weeks to if restock has arrived .
MASTER-BUILDER
#2 Posted : 05 May 2022 17:11:52
Rank: Amateur Level 1
You require
4.5 volt usb charging lead as a power source correctly terminated at the +/-
Do not go over this voltage as this is maximum output required
Good luck
admin
#3 Posted : 06 May 2022 06:34:43
Eagle- please bear in mind that anything like this will void the warranty on the motherboard, and as such, will not be replaced FoC.
Eagle
#4 Posted : 06 May 2022 12:59:22
Thanks: I did not know there was a warranty on the motherboard! How long is the warranty in effect?
admin
#5 Posted : 07 May 2022 05:02:30
In the past, it was pretty liberal. But, model kit motherboards are pretty far down on the chip radar, so it’s become a lot more stringent. But, in general, a year ish.
This page was generated in 0.091 seconds.
