5 Pages «<345
Hi, everyone, first time post. Options
Blighty
#81 Posted : 03 May 2022 16:48:55
Rank: Semipro Level 1
Getting close now, should have a close to completed model and display tonight.
Blighty attached the following image(s):
#82 Posted : 03 May 2022 17:02:35
Hi,BigGrin
Looking very good Cool Cool , if I may what adhesive are you using for the Perspex sheeting ?
I always used channelled wood strip on the vertical corners, but even as small as I`ve used they do get in the way of your view. Blink
Blighty
#83 Posted : 03 May 2022 19:02:40
delboy271155 wrote:
Hi,BigGrin
Hi Derek,
I use a purpose made acrylic adhesive that actually melts the edges together. Care must be taken to prevent over spill but I don't think that would be a problem for you!!. The wooden frame is 2 flat pieces of wood super glued to the edges purely for cosmetics to cover the bonded edges.
Also I use a thin acrylic sheet which obviously helps reduce the corner wood size. Attached is a pic of adhesive tube.
Blighty
#84 Posted : 05 May 2022 15:09:30
Hi, Well I have the case finished, just needs a cleanup of all the dust and it will be ready to display. I foundan old pic of Manchester city centre andwasgoing to paint a background of it for the Rocket, but I decided to look through my pile of acrylic painting I have, (another hobby of mine) and found a country scene that was suitable..................so, I trimmed it to size and that will now be my background pic, just need to get some 2 sided tape to hold it in place.
've added a couple of pics to show nearly finished display, hope you like it.
Blighty
Blighty
#85 Posted : 06 May 2022 18:08:05
I took the dog a walk this morning on the look out for some fine roadside gravel. Success, found enough loose gravel to fillin under the tracks. Washed, filtered and mildly sorted and the end result was better than I expected.
While the gravel was still wet after draining I added wood glue and proceeded to spread on base.
Should be dry tomorrow.
#86 Posted : 08 May 2022 14:29:57
Well I must say this is all looking good as you near the end. WTG
Cool Love Cool Love Cool
Don`t forget to post a few pics in a new thread of the "Finished Build Gallery" section of the forum to receive your RED medal (link here):
https://forum.deagostini....1652016375.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=109249990
Blighty
#87 Posted : 08 May 2022 18:37:30
Finished!!!! bit sad really, this was a fun model to build. Here's a final pic of the complete ensemble, like all the great masterpieces, best viewed from a distance.
Blighty
Blighty
#88 Posted : 08 May 2022 18:40:16
admin
#89 Posted : 09 May 2022 15:36:25
Nice display!
#90 Posted : 09 May 2022 16:18:49
That's a grand looking piece.
Well done to you sir.BigGrin
GilShapley
#91 Posted : 10 May 2022 07:51:27
Looking great, I do like the background you have added to the display
So what can we expect to see you build next ??
Gil
Current Build:-
Blighty
#92 Posted : 11 May 2022 01:27:27
Thx for following along, gotta find a new kit now.
Blighty
Blighty
#93 Posted : 11 May 2022 01:27:34
Blighty
#94 Posted : 11 May 2022 07:44:32
Very nicely done, the back drop looks great. Great work.Love Love Drool
RM1
#95 Posted : 11 May 2022 09:17:03
Brilliant way to display the model.ThumpUp ThumpUp
Very nice build. Thanks for sharing.
Malc.
kpnuts
#96 Posted : 11 May 2022 16:18:18
Nice display, looks great.
Guest (19)
5 Pages «<345
This page was generated in 0.227 seconds.
