GT40 Custom build PACK 8 Options
#1 Posted : 15 May 2022 14:48:17
This pack contains parts 26 - 30.
PART 26
This part is for the top of the dashboard.
An etched grill was added as this is missing from the kit part. The grill was a purchase from Ebay.
The dash top was sprayed satin black and then fitted to the dashboard.
PART 27
Parts included here are for the air vents, fuse panels and gear lever assembly.
All the parts were assembled as per the instruction but some detail painting was added to the vents and fuses.
At this stage the seat parts can be fitted.
PART 28
The pedal assembly and electrical switches are included here.
The chrome finish on the pedals can be toned down using an aluminium spray.
The switch parts are assembled as per the instructions.
PART 29
The steering wheel and colums are provided here.
De-seam the actual steering wheel perimeter and repaint matt black.
Assemble the parts.
PART 30
The steering rack and rack box are supplied here.
The rack assembly is actually in completely the wrong place compared to the real car so a 'dummy' rack will be added later on.
So that the kit rack isn't too obvious it could be painted matt black to obscure it.
Assemble the parts as per the instructions.
This page was generated in 0.433 seconds.
