10 Pages «<678910>
Tigerace`s 1/16 Trumpeter King Tiger Options
#141 Posted : 16 June 2022 10:18:20
Then built the tracksBigGrin
#142 Posted : 16 June 2022 10:21:38
Internal extinguisher painted just decal to add BigGrin
#143 Posted : 16 June 2022 18:34:01
Hi Phil, BigGrin
Looks good with some nice detailing.
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
#144 Posted : 17 June 2022 11:35:26
delboy271155 wrote:
Hi Phil, BigGrin
Thanks DerekBigGrin more scratch building at the moment on various missing partsBigGrin
Regards PhilCool
#145 Posted : 17 June 2022 12:53:08
Nice to see you back on this again Phil.BigGrin
#146 Posted : 21 June 2022 18:24:37
Thanks MarkBigGrin
philCool
#147 Posted : 21 June 2022 18:25:16
Fuel tanks paintedBigGrin
#148 Posted : 21 June 2022 18:26:58
Then started on the 3d printed drivers seatBigGrin
#149 Posted : 21 June 2022 18:31:16
Completed just needs paintingBigGrin quite pleased with it and it works awellBigGrin
#150 Posted : 21 June 2022 18:35:15
The accelerator conduit dosn`t go all the way to the front so i added the missing pieceBigGrin
#151 Posted : 21 June 2022 18:36:48
Started on the engineBigGrin
#152 Posted : 21 June 2022 18:40:42
Then made the missing gyrocompass transformer stand which sits just behind the driver`s seatBigGrin
#153 Posted : 21 June 2022 18:41:55
Then back on the engineBigGrin
#154 Posted : 21 June 2022 18:50:41
I then built up the 3d printed Inertia starter which is not included in the kit, most of Germanys Tanks in ww2 had this fitted and on the king tiger Engine the main coupling rod passes through the oil tank Cool a bit of surgery to the kits starter is required to fit the after market one , i also put a piece of tube into the oil tank as on the real tankBigGrin the other part to the starter which fits to the back plate and engine mount will be added later, all the parts except the main engine block are only dry fitted at this stage to aid paintingBigGrin
#155 Posted : 28 June 2022 11:52:13
Painted the engine before i assembled itBigGrin
#156 Posted : 28 June 2022 11:56:30
The batteries where painted and straps added from pewter BigGrin
#157 Posted : 28 June 2022 11:59:14
more parts for the engine carbs etcBigGrin
#158 Posted : 28 June 2022 12:10:49
Then started to assemble the engineBigGrin
#159 Posted : 28 June 2022 12:14:14
The two main interior fuel tanks installed into the hull also painted the fuel gaugeBigGrin
#160 Posted : 28 June 2022 12:15:39
The rear engine fire wall is now paintedBigGrin
10 Pages «<678910>
This page was generated in 0.969 seconds.
