GT40 Custom build PACK 18 Options
#1 Posted : 19 June 2022 15:00:56
This pack contains parts 76 - 80 and will allow you to build the main engine block.
PART 76:
Upper left cylinder head and cam cover.
The cam cover was sanded flat and repainted gloss black to match the parts in the actual car.
Assembly was as per the instructions.
PARTS 77, 78, 79 & 80:
Engine block left side, right cylinder head and cam cover, engine front and pulleys, engine block right side.
The cam cover was sanded and painted as per the previous part and the components assembled as per the instructions.
The front engine parts, pulleys and belts were detail painted before all of the parts were assembled.
The brake pipe parts were fitted to the rear wheel brakes and the frame.
The transmission and rear suspension parts can now be attached to the engine block, as well as the carburettors and 'turkey pan'.
This page was generated in 0.120 seconds.
