GT40 Custom build PACK 19 Options
#1 Posted : 18 July 2022 15:29:28
This pack contains parts 81 - 85.
PARTS 81, 82 & 83:
These parts were all de-seamed and repainted using a mist/mix of satin black, champagne gold and silver spray paints.
Gold was applied first, then a light mist of silver followed by a mist of satin black.
These parts were kept to one side and were fitted after the distributor and leads were added - next stages.
Do not fit the exhaust parts yet.
PARTS 84 & 85:
These parts build into the distributor and ignition leads.
If assembly is followed as per the kit instructions, the leads are extremely difficult to attach to the spark plug locations on the engine block as the exhaust manifolds are completely in the way.
The distributor should be fitted to the engine first.
Then each lead can be placed, cut to length and attached.
Once all the leads are in place the exhaust parts can then be added.
This page was generated in 0.135 seconds.
