GT40 Custom build PACK 20 Options
#1 Posted : 08 August 2022 10:47:53
The parts included here are packs 86 - 90.
These parts will build up into the rear oil cooler system and parts of the rear suspension.
Also included is the front lower body section.
PART 86:
This contains the oil lines for the rear oil coolers and are fitted as per the instructions. The moulded nut fixings can be enhanced by painting them silver.
PART 87:
This pack contains the anti-roll bar and Panhard links.
These parts should all be de-seamed and then repainted ally silver for a better effect.
Assembly is very straight forward.
PARTS 88 & 89:
These two packs allow you to build the rear oil coolers.
As with other parts, they should be de-seamed and repainted.
A wash of matt black over the mesh areas will enhance the appearance.
Assembly of these parts and connection the oil lines is done as per the instructions.
PART 90:
This part is the lower fron body section which is used later on.
This page was generated in 0.161 seconds.
