GT40 Custom build PACK 21 Options
#1 Posted : 09 August 2022 14:21:51
The set of parts included here are packs 91 - 95.
These parts will allow the completion of the front nose section.
PACK 91:
The parts here are for the front left headlight housing. They should be repainted satin black to looke the plastic appearance.
At this point, the lower nose section supplied previously was repainted dark blue after first removing the decals using acetone free nail varnish remover, and being primed in grey.
The lower lights were then fitted.
PACK 92:
These parts are for the right headlight housing.
Assembly is very simple and both left and right housings are fitted to the nose section here.
PACKS 93 & 94:
These packs contain the LED lights and covers for the front lower lights.
Once again, assembly is very straight forward.
PACK 95:
This pack contains the main body centre section which will be fitted later on.
This page was generated in 0.141 seconds.
