Display case and lightning and plinth stand Options
MASTER-BUILDER
#1 Posted : 11 December 2022 16:02:21
Rank: Amateur Level 1
Hi all
I have ordered the following items
www.acrylicdisplaycases.co.uk
Custom made display case with base
Made in 5mm acrylic
Length 800mm
Width 400mm
Height 300mm
Wood base colour is black ash
Centre of wood base is in black
Display gantry lighting from
www.display-lighting.com
DSPLED premium gantry surround profile luminaires
Size
Length 800mm
Width 400mm
Height 300mm
Clear diffuser ( full brightness)
Hidden fixing bezel / floating cover
Light brightness 5700K
Gantry finish anodised bright silver / chrome
Power system is plug and play with standard on/off driver with 2mtr mains cable
Plinth stand
www.retailacrylics.co.uk
Gloss black Perspex acrylic display plinth / pedestal
120cm tall x 40cm wide x 40cm deep
Hope this helps all forum members out on what is available to display there Ford GT40
Thanks
#2 Posted : 11 December 2022 16:14:56
Just wondering, if your gantry is the same dimensions as your display case, it will stand up on legs on top of the clear case.
Is that correct?
MASTER-BUILDER
#3 Posted : 11 December 2022 16:38:09
Measurement taken from hidden fitting and floating covers to achieve this
#4 Posted : 11 December 2022 16:59:35
Be good to see some pics when you have it all sorted.BigGrin
This page was generated in 0.031 seconds.
