3 Pages <123>
E Type low-drag 49 FXN 1/8 scratch build Options
#21 Posted : 04 May 2023 16:29:54
After a break from this one, I'm back on it again.
The next task is to check final main body placing and get the door fit correct.
Then I need to sort door hinges, door final fit and paint.
Then finish the interior, install the dash and steering wheel, then fix the body in place.
#22 Posted : 06 May 2023 18:06:46
Getting on with this one now as well as the Gunston Lola T70.
Doors now trimmed and sorted to fit.
Umpteen coats of primer, sanding, and three top coats.
The doors fit really well - just taped in place for the pics but the body is only loosely dropped over the tub.
Time to finish the interior, fix the hinges, then add the body to the main floor.
On we go from there.
#23 Posted : 26 May 2023 16:13:06
A small update on this one.
When finished, the doors will work so the interior can be seen.
I've added a matt black head lining which looks far better than the shiny clear plastic that was there before.
Dashboard in next, then the hinge assemblies for the doors.
#24 Posted : 27 May 2023 10:28:39
Ok, dashboard now in.
Steering column next, but not the wheel - yet.BigGrin
#25 Posted : 30 May 2023 10:28:36
I've managed to modify the kit door hinges and front panels and they are now in the shell.
Steering column and wheel added, gear and brake levers, and body placed for a rough idea of fit.
Looking aok so far.
#26 Posted : 05 June 2023 09:56:58
I've now added a roll cage which was made from a old guitar lead with the core pulled out, and thick copper wire pushed in.
I'm in the process of hanging the door skins and after that, the body will be added to the floor...
#27 Posted : 06 June 2023 13:43:20
The body is now fixed to the floor section.
Some cleaning up and touching up to do but so far so good - and the doors work.BigGrin
#28 Posted : 18 June 2023 08:44:24
Moving ahead with more of the body.
Rear wheel arch liners are now made and fitted. Painted matt black.
Also, the side windows have been made and are also now in place.
Door liner cards next and then it will be getting on with the front suspension and engine.
BigGrin
#29 Posted : 18 June 2023 09:12:50
Looking good Roy. Love Do you make the wheels too, or buy them in?
#30 Posted : 18 June 2023 09:41:27
Hello Mark.
I'll make my own wheels as on my previous E Type race car builds.
#31 Posted : 13 July 2023 17:43:34
I've been bashing along on this one for the past few weeks and the engine is now pretty much built and fitted to the car.
Lots more detail bits and wiring to add, as well as making all the other gubbins that goes around the engine.
On we go.Laugh
#32 Posted : 15 July 2023 11:00:02
Looking good Roy. Love It is amazing, given how big this engine was, that you could lift the bonnet up and work on pretty much anything to do with the engine, whereas you don’t stand a chance with modern cars. I had a TR4a with a 2.2L engine and you could virtually get inside with it. Blink
Kev the Modeller
#33 Posted : 16 August 2023 22:19:37
Lovely work as always Roy, looking forward to seeing more.
Well done! Cool ThumpUp
Kev
Per Ardua Ad Astra
#34 Posted : 20 September 2023 17:17:41
A long overdue bit of work on this one.
It's been sidelined a bit due to impending house move.
Anyway, screen rubbers now added...LOL LOL LOL
frah2o
#35 Posted : 28 September 2023 11:20:36
This is an outstanding work, and really a beatiful E-Type. My personal best E-Type body concept
#36 Posted : 19 December 2024 11:46:27
This one is now back on the bench again after nearly a year.
I thought it's about time I got on with it a bit more.
The oil tank and pipework will be next...BigGrin
#37 Posted : 06 January 2025 15:55:05
Making a start sorting the bonnet.
A lot of careful cutting and sanding needed here.
I don't want it to end up with wonky eyeballs!
Air vents next, then a good dose of filler, sanding and priming.
On we go...BigGrin
#38 Posted : 07 January 2025 11:33:08
Bonnet getting there.
Still need to add light opening rebates for the glass, the light 'buckets' and the inner air vent near the nose.
Then lots of filler...
#39 Posted : 08 January 2025 11:09:48
Light rebates sorted and the vent and intake walls.
First layer of filler and sanded.
A bit more filler still needed here and there and then on to primer...
#40 Posted : 09 January 2025 13:36:23
First coat of paint on the bonnet and light buckets.
More paint later, then when it's dry, fit the buckets and give it a polish.
Slowly getting there.BigGrin
3 Pages <123>
This page was generated in 0.356 seconds.
