 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,730 Points: 17,342 Location: ipswich
Ok, I'm potty... Another half-built glue bomb. Tamiya Lola but I'm going to rebuild it as a Team Gunston car after building the Lotus 72 in Gunston colours. It isn't quite the correct car, but near enough. On we go. roymattblack attached the following image(s):
Right - let the destruction begin. The main body had to be sawn apart from the floor due to the amount of glue, as can be seen in the picture showing the inside of the body and doors. The body parts were then also broken or cut apart. A LOT of cleaning up will be needed with all these parts. I managed to get all the rear suspension parts off, as well as anything on the interior. However, the front suspension has also been fixed very permanently in place so I've decided to leave well alone there as eventually it will be mainly silver or grey anyway. Once the floor part was cleaned up it was primed in grey, then some areas in white. Then the doorsteps and sills were sprayed orange. The logic of all this prep paint will become apparent later on... roymattblack attached the following image(s):
Talk about gluttons and punishment Roy!  Another masterpiece on the way! I meant to ask you a while back, I assume the white lettering decals you design are printed on to white decal paper, but how do you get the surrounding colour to exactly match your painted body work? I tried to do this on my Messines WW1 diorama some years back to get white numbers for the MkVI tanks but could never get the shade of green to match! Will be watching this one with great interest! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Hello Robin. To get my b/g colours to match the paint I print a 1" square in a colour that seems close and then compare it to the paint. I make a note of the RGB numbers of the colour. Then, I copy/paste the square next to first one which is then deleted. Go to the colour properties of the 2nd square and adjust the RGB as I see it. It can take many tries but eventually it gets there, or pretty close. And yes, glutton and punishment are sitting side by side on my bench...
Masked and sprayed... So the floor/chassis now looks somewhat better. Time to start on the interior. roymattblack attached the following image(s):
Hi everyone, this will be another one we all have to watch the car master create with his magic hands, I bet this one will be good. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Rank: Pro Groups: Registered
Where do you find these kits that have been completely glued up. Another one that will be a masterpiece. I’ll be watching your progress as usual. As it’s been said you are a glutton for punishment but you always get it right. Andy.
Many thanks for looking in and the kind comments chaps. I must admit I enjoy trying to rescue terrible wreck models with the hope of eventually giving them a 'finish' that they deserve. So far here, I've cleaned up and repainted literally everything - actually, 'painted' is more correct as everything was just bare plastic to start with. At the front I've added rad pipes, brake and clutch lines and flexible hoses to the calipers. None of this was part of the original kit. Decals drawn up and now printed. That was the best part of a day on its own. Along we go... roymattblack attached the following image(s):
Nothing major bodywise fixed together yet. Just placed to see how it looks so far. roymattblack attached the following image(s):
Rear firewall and body front now fitted properly and glued in place. Doors next... roymattblack attached the following image(s):
Ok, the doors. The side windows were utterly shot. Covered in glue smudges and very badly crazed. I tried careful cleaning using T Cut, but the window disintegrated. Out came the old trusty clear plastic drinks bottle from the recycling bin. The curve in a large 2 litre bottle was just right so a new window was cut and glued in place. The split-window effect was made by drawing a fine black line on the panel using a permanent marker. I've placed various parts to see how it is all going. Happy so far. roymattblack attached the following image(s):
Another update for anyone looking in. I've made a start on the engine and so far, no problems. Luckily this was a part of the kit not previously touched so I can only hope there are no missing parts. The rear suspension parts and wheels have been attended to as they were all horribly glued together and had to be broken apart, cleaned up and repaired so let's hope there aren't too many problems with the rest of those parts. Paint now sorted on the rest of the body. Nothing attached anywhere as yet - just testing the fit etc. roymattblack attached the following image(s):
This one so far. Engine etc all in, wheels on, body paint completed. Decals to go on then it's complete. roymattblack attached the following image(s):
Looking great, as always Ken's the name modeling's the game.
Many thanks Ken. It's actually now finished. roymattblack attached the following image(s):
Guest (8)
