Something Totally Different Options
#1 Posted : 13 May 2023 15:30:00
This is something totally different. I have a holiday home in Norfolk, have done for 40 years. We have a beautiful beach with lots of colourful beach huts. Whilst there a couple of weeks ago, I was looking at our lounge mirror which has a wooden frame around it which sticks out 10cm all around. It got me thinking about putting some model beach huts on the ledge, just the front part of the huts as the mirror image will make them look like you are seeing the whole thing.
I starting to think about how I would make these. Should I design one and 3D print it. Anyway, after making a sketch on a piece of paper, I decided they were going to be made in wood.
A few months ago, I bought a laser cutter/engraver but until now I’ve only ever engraved a glass with it. So, with my CAD design program, I designed a beach hut which then turns a 3D design into a 2D design for laser cutting. The design will give me around 15 different combinations of the huts so I can make them slightly different from each other as well as painting them different colours.
The hardest part was to use my little grey cells to work out how the software works and what setting I would need. The first attempt was not great. The hut looked like it had been burnt out as the laser was on a much higher setting that it should have been.
Anyway, I decided to make these out of 3mm MDF, the safe laser approved MDF without the nasty chemicals that you normally get with normal MDF.
Here are the results so far. I reckon I will need about 10 to fit along the shelf.
#2 Posted : 13 May 2023 17:44:48
Hi Mark, BigGrin
They look amazing, WTG Cool
goddo
#3 Posted : 13 May 2023 20:22:16
Hey Mark,
They look amazing. Well done and good luck with the rest of the huts.
My sister in law lives in Devon at a town called Budleigh Salterton and they have beach huts along the beach there too. So colourful and fun.
Chris
#4 Posted : 13 May 2023 23:17:16
Thank you Derek and Chris for your comments. It has opened up new possibilities with what I can laser cut now.
This page was generated in 0.121 seconds.
