 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
After a break from this one, I'm back on it again. The next task is to check final main body placing and get the door fit correct. Then I need to sort door hinges, door final fit and paint. Then finish the interior, install the dash and steering wheel, then fix the body in place. roymattblack attached the following image(s):
Getting on with this one now as well as the Gunston Lola T70. Doors now trimmed and sorted to fit. Umpteen coats of primer, sanding, and three top coats. The doors fit really well - just taped in place for the pics but the body is only loosely dropped over the tub. Time to finish the interior, fix the hinges, then add the body to the main floor. On we go from there. roymattblack attached the following image(s):
A small update on this one. When finished, the doors will work so the interior can be seen. I've added a matt black head lining which looks far better than the shiny clear plastic that was there before. Dashboard in next, then the hinge assemblies for the doors. roymattblack attached the following image(s):
Ok, dashboard now in. Steering column next, but not the wheel - yet. roymattblack attached the following image(s):
I've managed to modify the kit door hinges and front panels and they are now in the shell. Steering column and wheel added, gear and brake levers, and body placed for a rough idea of fit. Looking aok so far. roymattblack attached the following image(s):
I've now added a roll cage which was made from a old guitar lead with the core pulled out, and thick copper wire pushed in. I'm in the process of hanging the door skins and after that, the body will be added to the floor... roymattblack attached the following image(s):
The body is now fixed to the floor section. Some cleaning up and touching up to do but so far so good - and the doors work. roymattblack attached the following image(s):
Moving ahead with more of the body. Rear wheel arch liners are now made and fitted. Painted matt black. Also, the side windows have been made and are also now in place. Door liner cards next and then it will be getting on with the front suspension and engine. roymattblack attached the following image(s):
Looking good Roy.  Do you make the wheels too, or buy them in? Mark Regards Markwarren (Mark) Admin
Hello Mark. I'll make my own wheels as on my previous E Type race car builds. roymattblack attached the following image(s):
I've been bashing along on this one for the past few weeks and the engine is now pretty much built and fitted to the car. Lots more detail bits and wiring to add, as well as making all the other gubbins that goes around the engine. On we go. roymattblack attached the following image(s):
Looking good Roy.  It is amazing, given how big this engine was, that you could lift the bonnet up and work on pretty much anything to do with the engine, whereas you don’t stand a chance with modern cars. I had a TR4a with a 2.2L engine and you could virtually get inside with it. Regards Markwarren (Mark) Admin
Lovely work as always Roy, looking forward to seeing more.
Well done!
Kev
Per Ardua Ad Astra
A long overdue bit of work on this one. It's been sidelined a bit due to impending house move. Anyway, screen rubbers now added... roymattblack attached the following image(s):
Joined: 05/04/2016 Posts: 720 Points: 2,163 Location: Ferrara
This is an outstanding work, and really a beatiful E-Type. My personal best E-Type body concept Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
This one is now back on the bench again after nearly a year. I thought it's about time I got on with it a bit more.
The oil tank and pipework will be next... roymattblack attached the following image(s):
Making a start sorting the bonnet.
A lot of careful cutting and sanding needed here. I don't want it to end up with wonky eyeballs!
Air vents next, then a good dose of filler, sanding and priming. On we go... roymattblack attached the following image(s):
Bonnet getting there. Still need to add light opening rebates for the glass, the light 'buckets' and the inner air vent near the nose.
Then lots of filler...roymattblack attached the following image(s):
Light rebates sorted and the vent and intake walls. First layer of filler and sanded.
A bit more filler still needed here and there and then on to primer...roymattblack attached the following image(s):
First coat of paint on the bonnet and light buckets. More paint later, then when it's dry, fit the buckets and give it a polish. Slowly getting there. roymattblack attached the following image(s):
