Silkspan/Modelspan questions Options
suey
#1 Posted : 30 May 2023 23:02:18
Rank: Semipro Level 1
Having seen one or two videos and searched this (and other forum (forii?)) , I have a few questions, not yet answered. I have a fair idea how ?span can be used to make sails, so no problem there.
So;
1) Just what is Silkspan/Modelspan? Are they just different names for the same thing. I've seen indications that it may be a form of tissue paper, so wood pulp or ...?
2) Where may it be obtained in the UK/EU. I know its primary use is probably for RC planes but their language is a bit different!!
3) Those descriptions that I have found indicate that there are various 'weights' but I have no idea what is suitable for sail making. I would guess there is some dependency on ship scale and size.
Any knowledge/help please?
Sue
#2 Posted : 31 May 2023 09:42:24
Hi Sue, BigGrin
Found a useful three part vid on You Tube (See link below for parts 1 and two, part three comes up on side panel)
https://www.youtube.com/watch?v=g_m_VWzk4w8
I`m pretty sure you will get Silkspan on ebay as it is as you say primarily used to cover model airplanes.
Hope this helps.
suey
#3 Posted : 01 June 2023 09:54:24
Thanks Derek. Darn, I replied to this yesterday evening, thought I'd saved it ... and it disappeared... s this is a test post, then I'll try recreate yesterdays post gggrrr
Sue
suey
#4 Posted : 01 June 2023 16:33:18
OK that seems to have worked. Back to post #2.
I think it was 2-3 years ago that I first came across those 3 videos mentioned by Delboy, and that was what attracted me to try this method. I haven't particularly pursued but now I'm taking another look. I'm fairly comfortable with how to to use silkspan to make some semblance of a sail, but I need to experiment first!
Which leads me to the other questions; just what is it and where to get it, preferably in the UK. In scanning other forums I found someone's link to Etsy, fine, how about Australian bookbinders offering of paper repair tissue...
And for some reason, I had not thought of trying Ebay. That becomes even more fun. Anyone for; silk fiber eyelash lengthening, silk curtains, silk skirts, silk shirts and on and on, the common factor being the word 'silk'. The only entry I saw for 'silkspan' (the search term) was for "Model Airplane News Magazine June 1998 - Rediscover Silkspan" from the USA. The £6.45 cost might be bearable if you were sufficiently interested but £24 postage (from US) is a tad over the top ... Ebay obsessed with 'silk'. I also tried 'modelspan', Ebay now obsessed with 'model'. So unless I strike lucky when someone is advertising...
Comes back to; can anyone help with where to obtain silkspan (preferably in UK) and what thickness/'weight' of material is best for sail fabrication?
Sue
#5 Posted : 04 June 2023 10:19:06
Hi Sue, BigGrin
Found this on ebay. It looks like a modern day equivalent of Silkspan as its used to cover model planes, just don`t know if it would work for sails in the same way.Confused Blink BigGrin :
https://www.ebay.co.uk/i...%7Ctkp%3ABk9SR5jT9dqQYg
suey
#6 Posted : 04 June 2023 15:05:00
Thanks for finding that Derek. Puzzled what your search argument may have been!! I have ordered 1 pack - just to see what it is and whether it may be suitable for sails (since no replies regarding what 'weight' is needed).
I shall see in a few days.
Thanks again Derek.
Sue
#7 Posted : 04 June 2023 15:26:22
Thanks again Derek.
Sue
Hi Sue, BigGrin
I just hope it works for you. Blink
Didn`t take note of the search criteria on ebay, but think it was "model aircraft covering" and then check through the listings as there`s lots of stuff.
Good Luck with the sails. ThumpUp
This page was generated in 0.158 seconds.
