 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Awesome! Your build is really inspirational Benny.
Awesome Build Benny Keep it up.
Chris..On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
Looks great Benny MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
and this was a christmas present from the wife  cheers benny
What a great present! You are a lucky man! :) Greetings, Walter
better than my presents!!! lucky sod “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Good to see an update from you! Quite a lot has been added since your last update, good luck with the rest of the build. Steve..
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Thats a really smart build there Benny and a great prezzi youve had you lucky man.
Foz
Good looking build you have there Benny. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Looks great mate. Well done.
jase wrote:better than my presents!!! lucky sod dont let your wife see that post cheers benny
thanks all for the comments.. i am doing the chainwhales and because i am painting my build do any of you think it will look odd if i leave the brass unpainted on the supports i have aged the brass supports by blackening them then rubbing the black off this has taken the shine off and looks like there old..i have already left the eyelets unpainted on the masts and on the deck,so really i wanted to know if visible brass will look ok on a painted victory cheers benny
benny wrote:thanks all for the comments.. i am doing the chainwhales and because i am painting my build do any of you think it will look odd if i leave the brass unpainted on the supports i have aged the brass supports by blackening them then rubbing the black off this has taken the shine off and looks like there old..i have already left the eyelets unpainted on the masts and on the deck,so really i wanted to know if visible brass will look ok on a painted victory I think the Brass looks good against the black. at the end of the day if you like it do it. PS wife doesn't look at this site, if she did I would have to do the Zero under an alias!! “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Benny whatever your comfortable with works!!!!its your build  its sounds a great combination  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi all i have put together the chainwhales and opted to leave the brass and deadeyes unpainted all i need to do now is varnish them and add the blocks...i followed sob's idea to use eye pins because i too found the brass too brittle  cheers benny
hi all ,the booms are painted rigged and finished.there painted the same way as the masts  cheers benny
Coming on great Benny  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Great job Benny... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Guest (28)
