17 Pages «<1112131415>»
benny's build Options
StefanDV
#241 Posted : 10 October 2011 21:19:42
Awesome! Your build is really inspirational Benny.
#242 Posted : 10 October 2011 22:49:04
Awesome Build Benny Keep it up.Cool Cool
Chris..
benny
#243 Posted : 11 October 2011 22:15:11
thanks all
cheers benny
benny
#244 Posted : 30 December 2011 12:45:09
hi all i hope you all had a good christmas and all the best in the new year i havnt been about much because of work commitments but i have manage a few day on my build..i am not finishing the painting of the upper hull until we receive the bottom wriggles because installing them will mess up the paintwork..i have finished the bottom hull and installed some deck fittings and i have put columns instead of 3x3mm wood
cheers benny
#245 Posted : 30 December 2011 12:46:15
Looks great BennyBigGrin
benny
#246 Posted : 30 December 2011 12:46:59
and this was a christmas present from the wife BigGrin
cheers benny
DaDokta
#247 Posted : 30 December 2011 13:27:38
What a great present! You are a lucky man! :)
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#248 Posted : 30 December 2011 14:19:54
better than my presents!!! lucky sod LOL LOL
farrabass
#249 Posted : 30 December 2011 15:57:02
Good to see an update from you!
Quite a lot has been added since your last update, good luck with the rest of the build.
Steve..
Foz
#250 Posted : 30 December 2011 19:30:48
Thats a really smart build there Benny and a great prezzi youve had you lucky man.
Foz
#251 Posted : 06 January 2012 20:02:45
Good looking build you have there Benny.
tom.ganc
#252 Posted : 08 January 2012 16:03:47
Looks great mate. Well done.
benny
#253 Posted : 08 January 2012 18:02:29
dont let your wife see that postBigGrin
cheers benny
benny
#254 Posted : 08 January 2012 18:09:52
thanks all for the comments.. i am doing the chainwhales and because i am painting my build do any of you think it will look odd if i leave the brass unpainted on the supports i have aged the brass supports by blackening them then rubbing the black off this has taken the shine off and looks like there old..i have already left the eyelets unpainted on the masts and on the deck,so really i wanted to know if visible brass will look ok on a painted victory
cheers benny
#255 Posted : 08 January 2012 19:47:43
I think the Brass looks good against the black. at the end of the day if you like it do it. BigGrin
PS wife doesn't look at this site, if she did I would have to do the Zero under an alias!!Mellow
#256 Posted : 08 January 2012 21:32:23
Benny whatever your comfortable with works!!!!its your buildBigGrin its sounds a great combinationBigGrin Regards Mike
benny
#257 Posted : 19 January 2012 16:16:07
hi all i have put together the chainwhales and opted to leave the brass and deadeyes unpainted all i need to do now is varnish them and add the blocks...i followed sob's idea to use eye pins because i too found the brass too brittle
cheers benny
benny
#258 Posted : 21 January 2012 18:48:13
hi all ,the booms are painted rigged and finished.there painted the same way as the masts
cheers benny
#259 Posted : 21 January 2012 19:11:27
Coming on great BennyBigGrin Regards MikeCool
#260 Posted : 21 January 2012 19:41:19
Great job Benny...ThumpUp
This page was generated in 0.761 seconds.
