Infinity Gauntlet Official Build Issues 22 - 26 Options
#1 Posted : 10 October 2023 16:14:58
Well, Hi Again. BigGrin
The updates keep coming and this one is for Issue 22 ThumpUp that starts the next pack of parts.
This pack consists of the following:
Issue 22: Addition of the Wrist Guard
Issue 23: Parts supply only
Issues 24 - 26: Cover the first three stages of the index finger construction.
Issue 22 update:
Parts supplied are as always shown in Pic 1.
Please note: Whilst working on the back of the Gauntlet, I remove the stones to avoid damage and replace them when the construction is finished.
Begin by positioning the Wrist Guard at the bottom (inside) of the back plate. Pic 2. Then whilst keeping the guard in place, fix it by using 5 x 01 type screws as shown in Pic 3 by the yellow circles.
That finishes this update and with the stones replaced the back of your Gauntlet should be the same as the one shown in Pic 4.
For continuity reasons, I will post an update soon for Issue 23 to show the parts supplied.
Take care and enjoy your wonderful hobby. Cool Cool
(Derek) Admin
#2 Posted : 10 October 2023 16:23:31
Hi All, BigGrin
As stated this Issue 23 is parts supplied only.
So, check that you have the correct parts and stow them away safely until required.
Parts should be as shown in Pic 1.
That`s it, so I`ll see you soon for the update of Issue 24.
(Derek) Admin
#3 Posted : 11 October 2023 17:55:44
Hi All, BigGrin
Next update for the Infinity Gauntlet is here and is for Issue 24. This is the first part of the build that starts the make up of the Index Finger.
Parts supplied are shown in Pic 1.
Bring parts A13 and A14 to the table and line them up as in Pic 2. Position part A13 inside A14 so that the screw holes line up, with the hole in A13 sat on the post of A14. Pic 3.
Hold the parts firmly together and fix them with the use of a type 01 screw. Pic 4.
Pic 5 shows the completed stage and part C04, which will be used in the next update Issue 25.
Take care and see you soon.
(Derek) Admin
#4 Posted : 13 October 2023 21:26:56
Hi Again to you All,BigGrin BigGrin
This is the update for Issue 25. The next update for the Index finger that completes the tip.
To start, bring the assembly and part C04 back from Issue 24 and add part C05 from this issue to the table and position them as shown in Pic 2. Please also pay attention to the points indicated (in Pic 2) that line up when you then bring the parts together as shown in Pic 3.
Now whilst holding the parts together and ensuring that the "T" shaped tab and the "semi circular" tab are still in place within the holes in the parts C04/05, fix the parts together using a Type 02 Screw. Pic 4.
Leaving that assembly to one side for now, position part D04 and A15 (from this issue) and fix them together with the use an 01 type screw, as shown in Pic 5.
Bring the two assemblies from this stage together as shown in Pic 6. Then press the parts together until they click together. (Applying the pressure gradually).
When the two assemblies have clicked together, they should replicate that shown in Pic 7.
That completes the very tip of the Index Finger and this update.
The final update for this pack (Issue 26) will be here soon.
Until then, take care. Cool
(Derek) Admin
#5 Posted : 15 October 2023 16:43:07
Hi All, back again, BigGrin LOL
Its time for the final update of this pack, with Issue 26.Cool
This issue is the continuation of the Index Finger part of the build.
Parts supplied with this issue are shown in Pic 1.
We start with the positioning of the washer onto part C06 (both supplied with this stage). Pic 2.
Bring the Tip section of the Index Finger (Issue 25) back to the table and insert the long spindle with the washer on it from the last step, through the previous assembly as show in Pic 3.
With the previous assembly still on the table, bring in part A16 also from this issues parts.
I now want to draw your attention to Pic 4. You will see that a lug and hole on these parts can link together as indicated. So, position the parts together with the lug inserted in the hole of the other part Pic 5. Note at this point, there is nothing that fastens these parts together.
With the previous parts in position, place part D05 as shown in Pic 6.
To conclude this update, secure part D05 using a type 02 screw as shown in the final Pic. Pic 7.
I`m now at the mercy of parts delivery, so will see you all as soon as possible.
(Derek) Admin
This page was generated in 0.268 seconds.
