Hi All,
As stated this Issue 23 is parts supplied only.
So, check that you have the correct parts and stow them away safely until required.
Parts should be as shown in Pic 1.
That`s it, so I`ll see you soon for the update of Issue 24.
Regards delboy271155 (Derek) Admindelboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All,
Next update for the Infinity Gauntlet is here and is for Issue 24. This is the first part of the build that starts the make up of the Index Finger.
Parts supplied are shown in Pic 1.
Bring parts A13 and A14 to the table and line them up as in Pic 2. Position part A13 inside A14 so that the screw holes line up, with the hole in A13 sat on the post of A14. Pic 3.
Hold the parts firmly together and fix them with the use of a type 01 screw. Pic 4.
Pic 5 shows the completed stage and part C04, which will be used in the next update Issue 25.
Take care and see you soon.
Regards delboy271155 (Derek) Admin delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Again to you All,
This is the update for Issue 25. The next update for the Index finger that completes the tip.
To start, bring the assembly and part C04 back from Issue 24 and add part C05 from this issue to the table and position them as shown in Pic 2. Please also pay attention to the points indicated (in Pic 2) that line up when you then bring the parts together as shown in Pic 3.
Now whilst holding the parts together and ensuring that the "T" shaped tab and the "semi circular" tab are still in place within the holes in the parts C04/05, fix the parts together using a Type 02 Screw. Pic 4.
Leaving that assembly to one side for now, position part D04 and A15 (from this issue) and fix them together with the use an 01 type screw, as shown in Pic 5.
Bring the two assemblies from this stage together as shown in Pic 6. Then press the parts together until they click together. (Applying the pressure gradually).
When the two assemblies have clicked together, they should replicate that shown in Pic 7.
That completes the very tip of the Index Finger and this update.
The final update for this pack (Issue 26) will be here soon.
Until then, take care.
Hi All, back again,
Its time for the final update of this pack, with Issue 26.
This issue is the continuation of the Index Finger part of the build.
Parts supplied with this issue are shown in Pic 1.
We start with the positioning of the washer onto part C06 (both supplied with this stage). Pic 2.
Bring the Tip section of the Index Finger (Issue 25) back to the table and insert the long spindle with the washer on it from the last step, through the previous assembly as show in Pic 3.
With the previous assembly still on the table, bring in part A16 also from this issues parts.
I now want to draw your attention to Pic 4. You will see that a lug and hole on these parts can link together as indicated. So, position the parts together with the lug inserted in the hole of the other part Pic 5. Note at this point, there is nothing that fastens these parts together.
With the previous parts in position, place part D05 as shown in Pic 6.
To conclude this update, secure part D05 using a type 02 screw as shown in the final Pic. Pic 7.
I`m now at the mercy of parts delivery, so will see you all as soon as possible.
