Do I need any glue at all to build this model? Options
f13dfx
#1 Posted : 18 October 2023 19:14:31
Rank: Amateur Level 2
Red Medal: Red Medal
I’ve had this 1/4 scale Yamaha YZR-M1 since before the pandemic & just getting the time, now that I’ve semi-retired to build this model.
Was wondering if any glue was needed for building this model. I’ve watched a few YouTube videos of how it’s put together & for the most part it’s all done with screws, but I may be wrong.
If glue was needed, what brand & type would you recommend? Thanks in advance!
#2 Posted : 18 October 2023 19:23:39
Was wondering if any glue was need for building this model. I’ve watched a few YouTube videos of how it’s put together & for the most part it’s all done with screws, but I may be wrong.
Hi, BigGrin
To the best of my knowledge, there should not be any need for glue.
Where the kit is a bolt together (screw together) its very unlikely. At times you will get press in parts and the odd part may need the smallest spot of super glue should they be a little loose. To date I`ve not needed any glue on lots of builds.
Good luck with your build and enjoy your semi-retirement.
(Derek) Admin
Mustang
#3 Posted : 18 October 2023 22:32:11
Simply put no, you won’t need glue.
I’ve built the Honda and that was just screws.
Enjoy the build.
To build:-
f13dfx
#4 Posted : 21 October 2023 11:05:14
THANK YOU MATES!!!
This page was generated in 0.330 seconds.
