Joined: 05/04/2016 Posts: 720 Points: 2,163 Location: Ferrara
Having redesigned the intercooler and plenum assembly, I also revised the duct. I tried to give a dynamic sense to air flows. Having reduced the surface of the grill on the bonnet due to the presence of the air scope, I reduced the volume of air inlet for cooling my flat six. I redesigned the new IC conveyor giving it a new, more harmonious shape and I designed it with a double function: air intake for the intercooler and two lateral pods to bring cooling air to the upper part of the engine (the intercooler unit photographed in the photo from below is empty but will be closed) I calculated the dimensions with the body mounted to be able to remove it and leave the IC itself visible there... and finally I personalized it with the logo of my overall F1 driver. Once everything was printed and verified, I redesigned the sleeves and the pipe connecting the turbo to the intercooler. Latest mod: the reinforcement plates of the engine-turbo support bar. As well as giving a sense of reinforcement, they also hide the inevitable gaps in the chassis experienced by the change from naturally aspirated to turbo.           Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,814 Points: 17,594 Location: ipswich
Another fantastic update. Keep it coming.
roymattblack wrote:Another fantastic update. Keep it coming. Many many Thanks Roy! With paints, washing and pigments I completed the intercooler, sleeves, various flange tubes and the intercooler conveyor. I then started the carbon work on the door cards and CDA box. I wait 48 hours for the decals to rest and then I seal with clear coat. I then finished painting and highlighting the internal filter element of the CDA. I started work on the center lock for front rims only (there will be turbofans at the rear). To make my life easier, I designed the centerlocks so that they are fixed with slight interference on the head of the Allen keys in order to camouflage them.           Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Before start with the final painting of the body, I continue with the some details. I started filling the hole for the antenna housing on the mudguard and the various holes at the base of the front pillars where the switches for the courtesy lights would be housed. I then worked on the quick hooks for the bonnets. I have decided that both the rear and the front will be a single hook. At the rear only on the left side as there is no space on the right side due to the intake system and on the front instead of the two lateral ones only a central mono. I like it in the middle and it makes the line less heavy....while I'm posting I've already revised the dimensions of the front by tapering the bracket on the bumper and shortening the hook itself. I have made the hooks functional, the appropriate pin and bolts will follow.          Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Excellent build, it is just mind boggling where you are taking this. Well done. Regards Markwarren (Mark) Admin
Markwarren wrote:Excellent build, it is just mind boggling where you are taking this. Well done. Thanks Mark Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Another amazing update here. Keep it coming...
Beautiful paint job there, Francesco. Well done. Chris
roymattblack wrote:Another amazing update here. Keep it coming... goddo wrote:Beautiful paint job there, Francesco. Well done. Chris Many many thanks mates! Once the paper fiber texture of the paneling had dried, I continued with the painting job. I made the contours with a 0.7 ultra-fine tip uniposca pencil; I painted The inner surface with semi-gloss black. Again with the uniposca pencil I redid the surface where the grille will be fixed on the rear bonnet. While everything was drying and the bleach finished its work on the chrome, I worked on the chrome frames placed on the rear window and windscreen seals: here the operation was much quicker and simpler to remove the chrome. Cotton swab soaked in alcohol and stripping was quick and easy. In order not to miss out on training with fusion, I finished a project that I had in mind for some time: Console with switch mappings. 3 maps: road, race and kill (used for drag race) There are rumors that the race is enough to burn Ferraris and Lambos  . The Kill is never used.           Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Once I finished the chrome stripping the, I worked won another mod that I have always adopted on all my 1:1 cars too. The conversion from halogen headlight to bi-xenon. I designed the bixenon bulb by calculating the circumference for the future lens. After a base coat I then painted all the frames in matt black and the light reflectors in aluminium. The original chrome made the headlights too "Lexus style" in my opinion. I was afraid that when I painted the external handles black the Porsche engraving would disappear: by going slowly and with light coats it remained visible.         Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Just on a different level, excellent work. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Just on a different level, excellent work. Mark Many Thanks Mark! Another change that I was waiting to made: the darkening of the front/rear lights and indicator. The original chrome was dulled by a coat of aluminium, but the color of the lenses was still too bright. This is also a modification borrowed from my 1:1 cars and which is very early 90s tuning. I apply Smoked adhesive wrap and than hairdryer and both the front and rear light received a new look that suits my project perfectly. I Placed the 2 front lights with the new black headlight : everything is taking a nice aggressive look.         Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Once the xenon bulbs were printed I thought about how to create the lens of the xenon. I could have printed it with transparent resin... but buying 0.5 liters of resin for two these micro parts seemed excessive to me. The Lego bucket presented me with the solution. I made the lens and sanded it with 1000 and 2000 grit and water and then I polished it. The internal part of the bulbs were chromed with Molotov pencil, finally I mounted my 4300k xenon in the headlights of this 911. I finished the fenders by making the hood seals and assembling the full headlight assembly. Painted kill switch console, panel line to highlight the various maps and knob in its place.           Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Guest (9)
