Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
Latest bit of work on Titanic was internal and involved adding reflective stickers to two parts of the superstructure and they look far better without light bleeding through the walls. Not sure if the superstructure under the 3rd funnel will have any reflective stickers added or not at this stage, but it could do with some being added to it.
Hi That light blocking is a great improvement, hopefully more will be supplied at a later stage in the build. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Does look amazing.  You're going to need a big display cabinet for that. Mark Regards Markwarren (Mark) Admin
Update on Titanic. I still have to add some reflective stickers to the superstructure.
Woah, You gonna need a bigger table soon. Looks good. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
I need to do some wiring repairs to the underside of the foredeck and another section of hull has been added.
Start of the promenade deck.
Hi Anthony, Really coming along now and appreciate all the hours that must been spent getting this far. Well done, it's looking good. Chris
This build will go on hold for a few weeks as I am going cruising for 3 weeks.
Take the model with so that you can fill those empty hours with fun. On the other hand, perhaps not!! Hopefully the cruise will be all the fun you need. Enjoy. Chris
Where things are with Titanic. Screwed the frames in to see how they look on the Promenade Deck. Still have a gazillion windows to install.
Boat Deck sitting on top of the Promenade Desk after installing the windows in the prom deck.
Hi Skyfire, That is looking impressive. I was just thinking, I hope they don`t give you all the deck railings to fit in one go, there will be one heck of a lot. Keep up the good work.  Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
First two sections of the bridge deck.
Hi Skyfire, That is looking impressive, you are definitely gonna need a larger table and a super wide angle lens on the camera. Keep it coming, I love these large scale models.  Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Added two more sections to the hull.
The build is moving along nicely. Keep the updates coming. Hope the cruise was restful? Chris
Cruise went well apart from me falling over and hurtuing the back of my left knee, (tendon maybe).
Latest update to Titanic.
