Issue 6
Fitting The Oil Pan Place the oil pan bracket (06E) inside the oil pan (06D) and secure with 2 x DP screws, pictures 2 and 3. Place the oil pan assembly onto the gearbox housing (06B) and secure it with a DM screw, picture 4.
Completing The Gearbox Fix the bell housing to the end of the gearbox housing and secure with a DM screw, picture 5. Next, rest the slip yoke (06A) into the end of the gearbox housing, picture 6. Place the other half of the gear box housing onto the left one and secure them together with 2 x SM screws, picture 7.
Turn the assembly over and secure the gearbox bracket (06F) with 2 x AM screws as shown in picture 8.
Issue 7
Installing The Right Engine Bracket Secure the right engine connector (07B) to the right engine bracket (07C) using an AM screw as shown in pictures 2 and 3. Take the assembly bracket and fix it to the outside of the engine block (07A) securing it with an AM screw, picture 4.
Assembling The Distributor Take the distributor cap centre (07H) and push fit it into the distributor (07E) as shown in pictures 5 and 6. Next, remove the distributor cap plugs (07F) from the sprue, note you have one spare. Place all the cap plugs onto the distributor assembly as shown in pictures 7 and 8.
Tip: When placing these caps onto the distributor assembly, start with the centre and work your way around the outside. When placing the caps on, I didn’t push them down all the way, just placed them on enough for them to stay in place. After they were all assembled, I turned the assembly over and gently push it down on a hard surface, such as a worktop, to push them fully onto the distributor assembly.
Push the vacuum advance (07E) onto the side of the distributor as shown in picture 9.
Fitting The Distributor Bracket Secure the distributor shaft (07D) to the engine block using a TP screw, pictures 10 and 11. Finally push the distributor assembly onto the shaft as shown in picture 12.
Picture 13 shows the complete assembly for this issue.
Issue 8
Assembling The Oil Pan Take the oil pan parts (08C), (08B) and 2 x AP screws, picture 2. Assemble as show in picture 3. Push the oil pan hose bracket, (08E), onto the oil pan hose, (08E), picture 4. Push fit this assembly onto the side of the oil pan as shown in picture 5. Next, fit the oil pan top to the top of the assembly, securing it with 2 x AP screws, picture 6.
Assembling The Generator Take the parts, (08I), (08J), (08L) and (08K) along with a TP screw, picture 7. Fit the parts as shown in picture 8, 9 and 10, securing it all with the TP screw. Next, fit the generator (08F) and secure with another TP screw, picture 11. Place the rear cover as shown in picture 12. Place the assembly onto the right engine block, shown in pictures 13 and 14, and secure with a TP screw, picture 15.
Picture 16 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
