Infinity Gauntlet Official Build Issues 57 - 61 Options
#1 Posted : 11 June 2024 12:03:58
Hi All,BigGrin
Here we are with the next pack of the Infinity Gauntlet. This pack covers issues 57 - 61 and in these issues we will complete the middle finger and start construction of the inner forearm armour plates.
Issue 57:
Parts supplied.....Pic 1. You will also need the middle finger from Issue 56.
Position the part A31 over the top surface of the finger as shown in Pic 2. Then fix the part in place using a type 02 screw, Pic 3 and finish off by pressing the screw cover D10 into place, Pic 4.
Well that`s all for this update, Pic 5. See you soon for issue 58.
(Derek) Admin
#2 Posted : 13 June 2024 12:19:56
Hi All, BigGrin
Time for the next update, with Issue 58. In this update we add the next finger plate on the middle finger.
Parts supplied.....Pic 1. You will also need the middle finger from Issue 57.
Start by placing the armour plate A32 onto the middle finger, Pic 2. Then fix it in place using a type 02 screw, Pic 3 and cover the screw by pressing part D11 into place , Pic 4.
There ends another short update for the middle finger. Pic 5
The construction of the middle finger will be complete in the next update, with Issue 59. See you soon.
(Derek) Admin
#3 Posted : 15 June 2024 11:46:48
Hi All, BigGrin
I`m back with the next issue of the Infinity Gauntlet. This update is for issue 59, that will finish the assembly of the middle finger.
Parts supplied.....Pic 1. You will also need the middle finger from issue 58.
Place the armour piece A33 onto the finger, Pic 2 and then fix it in place using a silver type 02 screw, Pic 3. Now finish the finger by pressing the screw cover D12 into place, Pic 4.
That ends the assembly of the middle finger, Pics 5 and 6. It will be attached to the rest of the Gauntlet at a later date, so store it carefully until then.
I`ll be back soon with the next update. This will cover issues 60 and 61 as issue 60 is a part supplied only, with nothing to do.
(Derek) Admin
#4 Posted : 17 June 2024 14:16:13
Hi All, BigGrin
This is the update for Issue 60 of the Gauntlet.
Issue 60 is a part supply only, with nothing to do.
So, part supplied.....Pic 1.
Will see you very soon for the update of Issue 61. ThumpUp ThumpUp
(Derek) Admin
#5 Posted : 17 June 2024 14:38:21
Hi All, BigGrin
Well I`m back already with the Issue 61 update. LOL
We can now start the assembly of the inner forearm armour plates.
Parts supplied.....Pic 1. You will also need the part from Issue 60.
Bring the plate from issue 60 to the plate supplied in this issue and engage the posts and holes so they lay flat to each other, Pic 2. Then secure the two plates together, using 5 x type 01 screws (black) as shown in Pic 3.
That ends this update and pack, Pic 4. See you as soon as the next pack arrives.
(Derek) Admin
This page was generated in 0.867 seconds.
