 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
Stage 19 shows how to fit part 19F - Fuel tank breather hose, and part 19J - Fire extinguisher pull cable.
The parts list image on page 5 of the magazine shows incorrect parts for both pieces.
19F is shown as a longer black pipe when it is actually a shorter white pipe as supplied.
19J is shown as a shorter black pipe when it should be a longer black pipe as supplied.
The actual build instructions show the correct parts being fitted.
If you follow the parts list, you will fit a long pipe to the breather, leaving a pipe too short for the pull cable.
In a few instances, the parts supplied have both been black. This will not really matter as long as the correct long and short pipes are fitted in the correct places.roymattblack attached the following image(s):
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Or like me, you end up with a short black one and a short white one Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
