Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,348 Points: 22,351 Location: Northamptonshire, England
Issue 27
Assembling and Fitting the Frame Take the right middle frame (27A) and attach it to the left rear frame (27B) using 2 x CM screws, picture 2.
Take the assembly and secure it to the front chassis and rear crossmember using 2 x CM screws as shown in pictures 3 and 4.
Pictures 5 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 28
Assembling the Crossmembers Take the central crossmember, (28A) and secure it with 2 x CM screws as shown in picture 2.
Take the rear crossmember, (28B) and again secure it with 2 x CM screws, picture 3.
Pictures 4 shows the complete assembly for this issue.
Issue 29
Assembling the Rear Mount Take the two shock absorbers, (29B) and the rear mount, (29A) and secure the shock absorbers to the mount with EM screws, picture 2.
Take the assembly and secure it to the rear frame using 2 x CM screws as shown in picture 3.
Issue 30
Assembling the Spider Joint Insert the spider joint (30D) between the two flanges at the end of the slip yoke, (30C) and secure each side with an AP screw, picture 2.
Take the assembly and place it into the recess at the end of the rear axle housing, (30B) pictures 3 and 4.
Issue 31
Assembling the Rear Axle Place the rear axle side (31A) onto the rear axle (30A) and secure it with 2 x AM Screws, pictures 2 and 3. Next, secure the rear axle housing to the rear axle with 2 x AP Screws. Please note with way round the rear axle housing is fitted as shown in picture 4.
Finally attach the back axle cover (31B) in place by push fitting it on securely, picture 5. Note: Make sure you are happy with the fit of the axle assembly, I have taken a different view of the orientation of this part as shown in picture 6, as once this part is in place it will cover the screws.
Pictures 7 shows the complete assembly for this issue.
Issue 32
Assembling the Leaf Spring Place the left rear leaf spring (32A) onto the post on the rear axle. Note that the longer end of the leaf spring runs towards the back as shown in picture 2. Place the shock absorber mount over the leaf spring and secure with an EM screw, picture 3.
Push the ends of the āUā bolts (32C) through the holes of the mount and secure them with the small nuts (32D) using the supplied tool, (32F) pictures 4, 5 and 6.
Using an EM screw, secure the shock absorber (32E) to the notch on the side of the mount as shown in picture 7.
Pictures 8 shows the complete assembly for this issue.
The final picture 9, shows the complete assembly for this pack.
