 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Looks like they're out of stock of pack 6. Seems like it could be a common occurrence throughout this build☹️ Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Steve279021 wrote:Looks like they're out of stock of pack 6. Seems like it could be a common occurrence throughout this build☹️ Hi Steve,
I was in convo with CS at the end of last week over this very issue.
There are at this time several issues with the supplier that cover some/not all parts from 26 - 41.
I received pack 6 about 10 weeks ago, minus issue 26. At this time I should be awaiting pack 10 this month as I started my subscription last November at the first release. I only received issue 9 from pack 3 a few weeks ago.
It had been hoped that it would have been sorted by now, before those like yourself on the second release caught up, but unfortunately that has not been the case.
My contact at CS is out of office until the 12th September. so I will not get another update until at least that date. From my last convo with CS there is not an available time line at present.
You will also note that the same issue is affecting the Official Build.
I will update when I get any more info.
Regards delboy271155 (Derek) Admin
Sounds like it's the engine parts that are an issue as 26 is the start of the engine. The engine apparently is highly detailed so maybe the task of producing such small parts has been troublesome? Just an observation. Cheers for the reply👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looks like they've stocked up. Just been told that it's been sent from the warehouse👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve279021 wrote:Looks like they've stocked up. Just been told that it's been sent from the warehouse👍 That`s good news.
Regards delboy271155 (Derek) AdminCOME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
