Moomins Cellar Door Options
#1 Posted : 06 October 2024 11:44:54
One thing the Moomin’s house does not have is a door to the cellar. The natural place for this to be is to place it under the stairs, because the pull out cellar compartment already has the steps.
I have designed a doorway which will be laser cut using 2mm plywood and 4mm moulded plywood for the door frame. Here are a couple of pictures to show the sketch of the door and where it will be placed.
I’ll post more pictures once it is in place.
This page was generated in 0.024 seconds.
