Yet another wreck - Lotus 72 Options
#1 Posted : 23 October 2024 10:47:20
I've dug another one of these big Entex kits out of my pile.
Yes, it's half-started, extremely badly.
Another glue bomb, but this one is also a paint bomb.
For no understandable reason, parts are painted green and other bits are blue.
No matter as it will all have to come off anyway as it's going to be in the Lucky Strike scheme eventually.
First task will be to check nothing important is missing...LOL LOL LOL
#2 Posted : 23 October 2024 13:33:47
On we go.
After some careful dismantling (breaking it apart) the bits were soaked overnight in oven cleaner and washed, then sanded.
Now in primer and the cockpit is silver and the seat black.
These bits will go back together shortly.BigGrin
#3 Posted : 23 October 2024 18:55:58
A little done.
Interior parts reassembled and the side pods are now attached to the body panels but only at the upper edge so far.
The pods are incredibly warped so I've fixed the upper edge leaving the bottoms free.
When the glue is fully set - 24 hours?
I'll pull the lower edges in and clamp them, with some glue in the join.
#4 Posted : 23 October 2024 19:46:39
Hi Roy, Blink
You certainly know how to pick em. Crying
I`m sure it will end up very presentable in your hands.
Good Luck.
(Derek) Admin
andali15
#5 Posted : 24 October 2024 13:41:26
Another one to test your patients. I’m sure you get through and have a decent model in the end. Andy.
#6 Posted : 25 October 2024 15:14:04
Many thanks you chaps.
All good fun.
I've fixed the rear side pods into place now and the body sides are glued at the bottom edge.
I've built enough of these kits now to know the (numerous) pitfalls - one being that when the body tub is assembled, the front frame won't fit.
I'll put the front frame in place when the body lower joins are set, then 'wrap' the body sides around it and then add the upper front deck.
When all is dry, take the frame out again, knowing it will fit later on.
Front frame now mostly sorted and pipework added to it.
#7 Posted : 26 October 2024 11:19:01
The amount you’ve done of these type of kits Roy, you ought to start your own repair shop program.LOL
#8 Posted : 27 October 2024 17:39:29
Not a bad idea Mark. lol.
The body primer has hardened off for a good few days so now it's been masked and had 3 coats of gloss white.
Masking off tomorrow.BigGrin
#9 Posted : 30 October 2024 17:26:35
A wee bit more here.
Masking all removed, and I've cut off the protruding piece of the floor at the front of the body.
Another bit learned from previous builds of this kit.
If that part stays in place and the kit is built following the instructions, it is literally impossible to fit the pedals as the steering column is in the way, over the top and access through the rectangular hole between the brakes is a joke.
This way, the front cradle can be added and the pedals then fitted to the cut off piece, before being offered up from underneath.
Method in my madness...BigGrin
#10 Posted : 05 November 2024 18:14:13
More done here.
Main engine and gearbox assembled now so it will be lots of fiddly bits next.LOL LOL LOL
#11 Posted : 06 November 2024 18:01:59
Fuel lines, plug leads etc sorted and now work moves on with the rear end.BigGrin
#12 Posted : 21 November 2024 17:29:07
Another update on this one...
Many of the suspension parts were broken but they've been sorted now and assembled.
Some pipework added - still lots to go.
Exhausts also now added.
BigGrin
#13 Posted : 23 November 2024 18:51:33
Well done Roy great don't no how you do it a master at work.
Trev.
#14 Posted : 12 December 2024 18:19:16
Many thanks Trev.
I'm doing bits of this one every now and then between other stuff so updates are a tad irregular.
Wheels assembled and painted, tyres added and lettering on.
I found the rear wing is missing an end plate so I made one from sheet placcy.
Luckily it's a simple flat part.
Not so lucky - the dashboard part is missing.
I'm going to have to scratch make that bit.
On we go...BigGrin
#15 Posted : 13 December 2024 17:53:06
Righty-ho.
Replacement dash now sorted.
TBH, I created it it Serif Page Plus, printed it on photo paper and then stuck it to 80 thou plastic.
Once cut out, the rear had some gauge bodies added from bits in my scrap box.
The bezel on the large gauge is actually a spare 1/43 wheel rim.
I'll add wiring to the back before I fit it in the car.
Ignore the 'speckles' on the dash.
In reality, they aren't there.
#16 Posted : 14 December 2024 17:42:32
The home stretch on this one now.
The assorted body parts, wings, air box etc all in white primer awaiting respective top coats.
Engine pipework etc all sorted.
I've still got to print the decals but the art is done for them.
Another few days should see it sorted.
#17 Posted : 15 December 2024 12:14:04
Pretty much all the assembly work has been completed - a few detail bits to add - and all the body parts are in primer awaiting top coats of red or white.
I'll print the decals today so they should be ready to add tomorrow.
Hmmm... Next project???
GilShapley
#18 Posted : 15 December 2024 14:04:25
Next Project MMMMMMM
How about demolishing a large plate of Roast Turkey with all the trimmings. Add to this, a nice glass of something you enjoy. Followed by Xmas Pudding
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Happy Christmas to all our members
Current Build:-
#19 Posted : 15 December 2024 15:30:44
Sounds like a plan Gil...
Especially the last bit. BigGrin
Decals printed and most of the paint sorted.
Hopefully finished later tomorrow or Tuesday.
This page was generated in 0.121 seconds.
