Snoopy's House Official Build Pack 3 Options
#1 Posted : 23 November 2024 19:59:27
Issue 6
Assembling the Table Lamp
Take the table lamp parts and the LED, picture 2, and place the LED into one half of the lamp as show in picture 3. Apply a little quick drying glue to the inner pins and attach the other half of the lamp, picture 4. Place the shade over the top of the lamp holder, picture 5.
Attaching the Figurines
The figurines are held in place with quick drying glue. Carefully apply some glue to the slots in the mound and attach the figures as shown in pictures 6, 7, 8 and 9.
Fitting the Cushions and Characters on the Couch
Use double sided tape to secure the cushions and figurines on the couch as shown in pictures 10,11,12 and 13.
#2 Posted : 24 November 2024 13:36:04
Issue 7
Attach the figurine with quick drying glue as you did in the previous issue. Carefully apply some glue to the slot in the mound and attach the Snoopy as shown in picture 2.
Place the assembled table lamp from the previous issue and feed the cable through the opening in the tabletop. You may have to apply a little quick drying glue, pictures 3 and 4.
Place the battery into the circuit board as shown in pictures 5 and 6. Make sure the negative side faces the board and the positive, flat side, faces up. Attach the cable from the lamp to the board, making sure it is plugged in the correct way and that the grooves on the plug match the socket, picture 7.
Place the circuit board into the table frame, lining up the bottom switch and the four pins, picture 8. Now close the assembly by snap fitting the pins into the tabletop, picture 9. Note: Do not glue in place as you will need to open for battery replacement.
Take the four legs for the table, picture 10 and place into the underside of the table, pushing the rectangular pins into the slots, picture 11. Picture 12 shows them in place with the lamp lit.
The final two picture show the lamp in place with the rest of the couch scene.
#3 Posted : 26 November 2024 10:50:33
Issue 8
Laying out the Cookies
Take the individual pieces of all the cookies and place a small piece of double-sided tape to the underside, and place then onto the tray as shown in picture 2.
Assembling the Back Wall and Window
Take the back wall frame and lay it on a flat surface top side up and place the window into the slot, pictures 3 and 4. Turn the assembly over and place the clear plastic into the top of the window frame, picture 5. This will only fit one way. Make sure you remove its protective film on both sides first.
Using a craft knife, separate the spacer parts from its sprue, pictures 6 and 7. Using a small amount of quick drying glue, place six of the spacers over the pins as shown in picture 8. Keep the other two spares for next time.
Stick the blue background to the back of the “relaxing home scene” approximately 3cm from the right-hand edge, picture 9. Temporarily place the assembled back wall into the three tabs at the bottom edge. Do not glue in place, picture 10.
Take the power pack from the previous issue and place 4 x AA batteries in, picture 11. Plug the battery box cable into the switch circuit as shown in picture 12 and then plug the cable from the back of the baseball theme into the other connector.
Finally, glue Charlie Brown in place as you did with the other figurines.
Now switch the battery box to the on position and then the switch circuit to light up the “Peanuts” sign. Picture 13.
This page was generated in 0.217 seconds.
